Question about Sony CDX-M8800 CD Player
CDX-M8800 won't read CD-R discs
My CDX-M8800 was working just fine but now it won't read CD-R discs.
Whenever I insert a CD-R mp3 disc, it says "READ" for a while, then it shows "ERROR" and ejects the disc. I thought it was dirty because, if I keep on inserting the disc back again, SOMETIMES it reads just fine. Once it reads, I can play the whole disc with no problems, but if I turn my car off or if I switch to Tuner, the problem starts again as soon as I try playing the CD again. It usually takes A LOT of retries to get the cd player to read the mp3 disc.
I tried a lens cleaner (the CD that has a small brush on it). It was then that I noticed the problem is with CD-R's (not sure if ALL CD-R's or just data/mp3 CD-R's), as when I inserted the lens cleaner CD, it played perfectly and instantly every time.
I would really appreciate some help with this, as I really love my cd player and I would rather not change it.
Thanks all.
  • robertoc7 Oct 19, 2007
    By the way,
    The CD-R I'm trying to play is NEW. It contains mp3 files only. Like I mentioned, it reads with no problems SOMETIMES.
    I just burned another disc at 12x (the slowest speed my burner seems to support with Nero 6 Ultra) and still no luck.
  • robertoc7 Oct 21, 2007
    Thanks for trying, but as you can read in my post, I DID make the disc myself and I recorded it at the slowest speed my burner would allow (12x) so that's not the issue.
    The problem also occurs with CD-R's that were already playing well. They are not scratched or dirty. They simply stopped playing from one day to the next.
  • 3 Answers
I was going to sugest switching brands of blank cdrs but you say ones that were working fine are now not ...so the problem is with the stereo not the cds.
 did you try a lens cleaner the eye may be dirty ..or possibly going bad.. Hey does it read regular bought disks ok???
Posted on Nov 01, 2007
Hi mate did you make the cd if so make the cd on slow speed it will work then max of 16x on you cd ok mate
Posted on Oct 20, 2007
SOURCE:
Cd player reads error 04
The error 4 in most Sony stereos is an error that comes up when the laser pickup doesn't read the disc correctly. This happens most of the time because of a dirty lens in the laser pickup. If anyone smokes in the vehicle the smoke may be on the lens causing the error code. Try a wet type CD cleaning disc to see if it helps.
Dec 03, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Sony CDX-CA400 FM/AM Compact Disc Player
The optic inside the CD player may be dirty or damp, this is the part that reads the data from the cd, you can try cd cleaning discs or you may have get an engineer to open it and clean it with an alcohol swab. The optic could also be faulty which will be cheaper to buy a new cd player.
Dan.
Dec 04, 2009 | Sony CDX-CA400 CD Player
It can't read dvd disc, but if i'm using an mp3/cd its fine
Was this a burned dvd or a store bought one? Sounds like the laser that reads dvd is dirty, try to play another dvd and see what happens after cleaning.
Nov 05, 2009 | Jensen's VM9312 Car DVD Player
Does not read disc
use a dvd lense cleaner if that doesnt work take it to a game shop it prob the lasor.
Jul 15, 2009 | Microsoft Xbox 360 Console
CDX-f500
Have you tried cleaning the unit with a "Laser Lens Cleaner?" one that uses fluid? Mp3 is a fickle format and your deck may be having issues reading it. Try running a cleaner thru it. Secondly, when you burn discs, make sure you finalize it by making it "compatable for all player types" Hope this helps
Jun 25, 2009 | Sony CDX-F7500 CD Player
CDX-FM65????? DOES IT EXSIST???
CLICK HERE for the specs on the CDX-FM653
No manual is available from pioneer for download.
ERROR 11 on pioneer cd players is common.
It can be due to a failing laser or dirty lens. It means that the CD was not recognised, either because of the CD scratched, or it could possibly mean the laser is out of alignment.
If the player works fine with other discs - chances are it needs a good cleaning.
If the player wont read any discs - it's time for a service call. Typically - I charge $50USD for clean and alignment.
you can do it yourself (clean it) by disassembling the player, and using a qtip and isopropyl alcohol - however an alignment requires a special alignment tool.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 16, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
Sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
Sep 08, 2007 | Sony CDX-M8800 CD Player
Sony CDX-M8800 CD Player Logo
198 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
