Question about Dodge grand caravan clip. liquid line attaching, with air
How do i attach metal spikes to vibracrete wall
  • 653 Answers
Drill holes in the concrete wall with a hammer-drill and either use expansion anchors or epoxy the spikes into the holes.
Posted on Jan 03, 2014
I can't figure out how to get my older roper microwave off the wall
If there is a grill above the door, remove it. There will be two long screws that attach the unit to a metal plate. The metal plate is bolted to the wall. Once you loosen the long screws, the unit will tilt down and come off the wall.
Jan 15, 2014 | Roper Microwave Ovens
What is the benefit of metal cleats as opposed to plastic ones?
Plastic cleats have the spikes permanently molded into
them. The spikes on metal cleats can be
screwed in or out. Therefore, if you have the option of changing the size or removing them when they get worn in.
Feb 06, 2013 | Baseball & Softball
What are track spikes made from?
Track spikes can be made from ceramic, metal and plastic and they are screwed into the bottom of the training shoes.
Jan 14, 2013 | Sport & Outdoor - Others
Hi There, we've bought a SX62 Baumr-AG chain saw. On page 8 of the instruction manual - Point 3: "Install the attached spike to the power unit" - there is no diagram that refers to this...
I have just bought one and the manual is hopeless but finally I figured it out. If you have installed the chain and guide you will need to remove them, then with the saw lying on the side and chain cover off you will see two holes on opposite side of the oil tank/engine casing
Nov 05, 2010 | Garden
I'm removing a Maytag microwave over stove model #mmv4205aab. Would appreciate guidance. The only attachments I can see are two bolts which connect the unit to the cabinet above. I cannot see what...
Typically there is a metal mounting plate screwed to the wall and when you take the screws out of the cabinet above it it will tilt forward toward you and then you have to lift it off of some metal tabs that are on the bottom of that mounting plate. Lift up and pull away from the wall and let the cord pull out of the hole in the bottom of the cabinet. Good luck. I usually do that by myself and hook one arm under it and lift it up, but probably better with two people.
Oct 09, 2017 | Maytag MMV4205 Microwave Oven
Projector fires up, menus display, search finds the attached computer but all that displays is a blank screen, no desktop. We had a lightning storm last week that spiked a network switch and two printer...
try brand new cables. I think a spike would possibly do this, doubtful though since the projector itself is not fried. also try reflashing the unit with the newest firmware.
Jun 30, 2010 | InFocus LP 820 Multimedia Projector
Do I have to tear out my wall?
If I understand you right the metal connector is on the wall connector and the wire is off of it if this is the case take some pliers and take the connector off the wall then take the connector and put it back on the wire just slip it in and squeeze the bottom of the metal connector so it tight on the wire this should help..
Nov 22, 2007 | Monster Cable (109611)
Dodge grand caravan clip. liquid line attaching, with air Logo
70 people viewed this question
Top Mopar Performance Vehicle Parts & Accessories Experts
Timllfixit
unosuave
Are you a Mopar Performance Vehicle Part and Accessory Expert? Answer questions, earn points and help others
