Question about Fellowes Powershred P-45C Shredder
Will not work after paper jam removal
Paper jam removed all the paper now it will not work at all. motor comes on but will not receive paper.
  • 133 Answers
SOURCE: Paper won't go through
already death for your shredder. Please go buy a new one.
Posted on May 23, 2009
JayBlair
  • 328 Answers
SOURCE: Fellowes Paper Shredder P70CM paper jam
Clean the upper and lower sensors with a cotton swab moistened with rubbing alcohol.
Posted on Jun 22, 2009
SOURCE: paper gets jammed. Even shredding just one sheeet
The problem was solved by putting some oil on the top of the shredder and running the motor forward and in reverse to coat the teeth. Thank you.
Posted on Oct 18, 2009
SOURCE: Paper is stuck in the shredder, and it won't
This just barely happened to me - I used needle nose pliers and a kitchen butter knife. It took 30 min but it will come out. Good luck!
Posted on Feb 06, 2010
SOURCE: Motor runs, but will not shred any paper, it won't
Sounds like the same problem im having. I opened mine up and the gears that run the teeth are stripped, and im having a real hard time finding new parts.
Posted on Oct 07, 2010
Hi, I have several jams in a ir canon 5000, in the vertical path with delay in the PS24 sensor. I exchanged that sensor getting the same result. Someone have had the same problem?
Doubt motor, suspect slipping paper feed roller in area just before ps24 area, or slipping clutch or obstruction in paper path. Ensure your using fresh paper, not old as it curls and causes issues. Rare is it a motor fail, especially if issue is sometimes rather than everytime. Clean clean is usally the fix or most paper path problems. Paper dust often makes rollers and feed tires slip rather than grip. Cheaper paper gives off more paper dust and causes more wear. Slightly damp rag just with water on rubber rollers is the best tool.Good Luck.
Jun 10, 2016 | Canon Service Manual For Ir 5000
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Hi there I have a canon Pixma MX360. The printer got a paper jam and I have removed all the paper that was jammed in the printer, however when I press OK to confirm the paper has been removed the settings...
You must check carefully to make sure all paper is removed, even little pieces that may have been torn. Use a flashlight and check very carefully in the paper path, also look down the paper chute, and where the paper exits.
Aug 03, 2011 | Canon Pixma MX360 Printer
I had a paper jam and cannot remove all the jam Is there a way to get to the roller to remove the rest of the paper? thanks alfretg@roadrunner.com My printer is anHPphotoshop 7260
There will be a rear access panel that you remove to get to the paper to fix paper jams.
You should never try to clear a jam from the front of the printer.
Mar 25, 2011 | HP Photosmart D7260 Printer
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Can't get it to work after a paper jam.
Inorder to remove the paper jam inside, you need to remove the toner cartridge first and then you can pull out the paper jammmed. If there is still paper jammed inside. Open the printer power to roll over and paper comes out. If still paper still there, You can open the back side of the printer to remove some paper jammed.
Nov 13, 2010 | Dell 1320c Laser Printer
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Paper jam error
Check rear door for paper fragments check paper jam sensors ussally one front middle and rear make sure they arn't stuck, model make?
Oct 16, 2007 | Office Equipment & Supplies
Fellowes Powershred P-45C Shredder Logo
50 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
