Question about Janome Sewing Machines
Skipping stitches when i try to sew layers, e.g., quilt, or heavily interfaced items, it skips stitches. sometimes an entire row.
  • 4 Answers
SOURCE: machine skips stitches when sewing thru several layers of fabrics
Is your needle new? The needle needs to be replaced every 8 hours on a regular sewing machine, and the ULT benefits from even more frequent changes. Also try a bigger needle, if you're using a 75/11 move to a 90/14, make sure your needle matches what you're doing, you might not think those little needle tips differ much but they really do.
The manual also mentions if there is to much lint under the needle plate. Keep in mind all sewing machines need the bobbin area cleaned out every time you change the bobbin, but the ULT likes cleaning up down there about twice as often.
Posted on Nov 23, 2008
SOURCE: skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Posted on Mar 15, 2009
  • 201 Answers
SOURCE: when machine quilting sews fine when moving forward, skips stitches when moving away
Check your needle. Make sure it is not blunt, try a Size 90 Topstitch needle or Embroidery needle. If you are using a thread thicker than regular piecing weight, you need a needle with a larger eye and a larger scrarf - the hollowed out bit at the back of the needle. Also don't sew too fast nor change direction too sharply. If you need to do a sharp turn, let the machine "mark time" once at the turn before moving off in the new direction.
Pam
Posted on May 02, 2009
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
  • 96 Answers
SOURCE: why is my machine skipping stitches
this is caused by uneven winding of the bobbin, sometimes the spool of thread winds unevenly when it travels up and down the spool. the best solution i have found is to use small spools of thread when winding the bobbins
Posted on Dec 13, 2009
Skipping stitches, already change the needle what else could be?
What to Do If Your Sewing Machine Is Skipping Stitches
www.craftsy.com > Blog Home > Quilting Blog
Jan 22, 2014 - Skipped stitches when you'e in the midst of sewing are really aggravating, especially when they occur on highly visible topstitching. But don't ...
Four Tips for Solving Skipped Stitches - YouTube
? 1:49
https://www.youtube.com/watch?v=djJXwsUM8YY
Sep 30, 2013 - Uploaded by How To Sew
Visit www.howtosew.com for more sewing basics and easy p. ...Sewing Machine Repair Interview- Common Problems w/Stitches, Threading, ...
Jan 27, 2016 | Sewing Machines
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Janome 1600P skipped stitches
Normal top tension is 3-4; normal bobbin tension (iirc) is 35 grams.
I'm betting, though, that a new needle, right way around and the correct size, would solve your skipping problems.
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
Trying to quilt on my Hinterberg. First the thread kept breaking. Made some tension adjustments, now I am skipping stitches
possible problems
1) too thick for the feed dog to move the fabric forward need; lighter tension
2) are the upper and lower threads the same kind of thread?
3) is the thread feeding properly from above? sometimes the spool can snag the thread causing the tension to jump and skip stitches
My Memory Craft sews great until I start to quilt or use one of the different stitches and then the stitches either skip or become so tiney I can't pick them out.
Skipping could indicate you need to use a larger size needle.
Tiny stitches could be save reason, or the top thread is hanging up.
Sometimes the thread can wrap around the spool pin or catch on a rough surface on the end of the spool.
Be sure to use the correct size spool cap and if the thread is wrapping around the pin, a thread net can help.
Give the machine a cleaning according to the maintenance section of the manual for your machine, including cleaning the feed dogs, bobbin case, shuttle and surrounding area.
Make sure the feed dogs are up unless you are free motion quilting and the presser foot down.
This may seem elementary.........just trying to cover all the bases.
May 02, 2010 | Janome Memory Craft 9000 Computerized...
When machine quilting sews fine when moving forward, skips stitches when moving away
Pam
Apr 28, 2009 | Sewing Machines
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Skipping stitches
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
123 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
