Question about NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571 780071 Professionally Refurbished
DISPLAY ON NEC PHONE DARK - NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571 780071 Professionally Refurbished
I have an NEC '19 Multisync LCD 1920nx monitor. The display went blank and will not come back on. There's power going to it. It just doesn't display and image. How do i fix this?....thanks
the inverter or the lcd bulb may be out. inverters are cheap, bulbs are not. is the screen dark like its off or glowing black? if its dark like the bulb is off, next, look closely and see if you can make out a faint image on the dark screen, if so, it is likely the inverter.
Aug 05, 2010 | Mitsubishi Computers & Internet
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
The contrast of my LCD display has gone very dark. How do I lighten it back up.
With the phone turned off, use the volume up/down key to increase/decrease the display contrast.
Apr 09, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Display contrast - too dark
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
Dec 11, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Dterm 80 LCD display is defective, where do I get parts? How difficult is it to change?
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
Dec 08, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Can't find caller id function on NEC ETW-16DC-1 BUSINESS PHONES SYSTEM
You have to make sure the phone system you have has CID cards in it. What kind of card is in the Electra phone system.
Sep 08, 2008 | NEC ETW 16DC-1 Corded Phone
Display Problems
The only way to darken or lighten the display is to use the arrow keys when the phone is idle. try unplugging the phone and plug it back in. If that does not work you need to replace the phone.
Aug 04, 2008 | NEC Electra Elite 32D-1 Corded Phone
LCD display backlighting
If there are up and down arrows on the phone you should be able to press them when the phone is not picked up to change the LCD.
Jul 31, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Display contrast needs adjusted
press speaker button and dial 602+ up and down key to adjust the display. dial 601 to increase ring volume. DJ
Jul 25, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571 780071 Professionally Refurbished Logo
19 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
