Question about Velocity Micro Cruz Reader R103
How to factory reset
Camra wont work
How do i reset my zeki tablet when the factory reset wont work
on Zeki Tablet you had to hold both the "Reset" button and the "volume up" button at the same time for about 15-20 seconds it than boots into Safe Mode which you can select a full factory reset. NOT VOLUME DOWN.
If this fails, 1 888 999 4215 is Zeki support. If in warranty, tell them of failure of factory reset. They may request it be sent to them.
Jun 11, 2017 | Tablets & eReaders
I'm trying to do a factory reset
Terri, The links can show how to factory rest on a tablet.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Android tablet not working Factory reset using keys
http://www.androidtablets.net/threads/how-do-i-factory-reset-my-tablet.62022
Apr 20, 2016 | Tablets & eReaders
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    When i turn it on i get a message that says unfortunately,launcher has stoped wont let me do anything else
    You need to do a FULL reset.
    1. Power off unit
    2. Hold down POWER and Vol - (or Vol+ if Vol - doesn't work) until Android reset screen appears.
    3. Scroll down to factory reset and select it.
    4. Agree to reset
    Unit will reset itself and start over like it was brand new and you will lose everything that was installed. Most likely you have a corrupt operating system and this may help. However, many android apps will not work on that tablet as its an older tablet that does not have an upgraded OS available.
    Good luck
    May 25, 2015 | Ematic 7" Touch Screen Tablet
    My kurio wont finish loading how to fix
    You cant factory reset it. That only works on apple.
    Feb 01, 2015 | Kurio Touch 4S Handheld
    My nabi dreamtab wont reset why?
    There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiā„¢ Sync.
    Dec 20, 2014 | Tablets & eReaders
    Ellipsis 7 tablet stopped working Says Google has stopped and says launcher has stopped. 3 weeks old!#!???
    You may need to do a "factory reset" on it. If you do, see this... See this site... http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
    Jul 14, 2014 | Tablets & eReaders
    Upon booting the tablet it says com.androidserver is not working
    Try resetting tablet by pushing a pin into the reset hole.
    Best solution woudl be to do a factory reset in all honesty - see here!
    Apr 20, 2014 | ZEEPAD Tablets & eReaders
    Velocity Micro Cruz Reader R103 Logo
    43 people viewed this question
    Top Velocity Tablets & eReaders Experts
     Mikey
    Mikey
    deton8 von Splosion
    Are you a Velocity Tablet and eReader Expert? Answer questions, earn points and help others
