Question about Dell Computers & Internet
Http 192 169
Problem printing to my Epson wireless printer. I've tried everything. Still not working.
  • Dell Master
  • 7,993 Answers
You have to install the printer as a wireless network printer.
If your router uses MAC address filtering you must reserve in the router DHCP an address (for example 192.168.1. 125) depending on the default or assigned gateway. The address must not conflict with another device.
When configuring the printer, you must also configure its network access by entering the passphrase.
Posted on Jan 02, 2014
Installed new ink cartridges. noyw when I try to print I get blank pages
FAQs - Epson XP-410, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
Epson[ Answer ]; How do I print with black ink when a color cartridge is expended? [ Answer ]; I see the message Printer is Offline when I try to print with a wireless ...
Epson XP-400, Top FAQs - Technical Support - Epson ...
Epson[ Answer ]; What should I do if my product is printing blank pages? [ Answer ]; I don'thave the CD that came with my product. How do I install the software for my ...
Epson XP-810, Top FAQs - Technical Support - Epson ...
Epson
Feb 05, 2016 | Epson Expression XP 410 Wireless Printer
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Can the epson R220 print wireless
It can't print wirelessly with the native hardware. It has a USB 1.1 connection. You may be able to find a print server that can connect to a wireless router. However, you will need to check the specifications. Some print servers will only work with select printers or OS combinations.
The specifications for the R220 are here: http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&infoType=Specs&oid=58654761&category=Products .
I hope this helps.
(note since this is an older printer with a USB 1.1 connection, you can expect the printer to be slow with a wireless connection. If your signal strength drops, you may need to reboot everything (computer, print server, router and printer).)
Mar 21, 2011 | Epson Stylus Photo R220 InkJet Printer
Incompatibility between Epson Printer and Windows 7
You probably need the correct driver for Windows 7.
Click on the link below and download the driver for the printer.
http://www.bioticaindia.com/stylus-cx-4700.html
Let me know if this driver works for you, also it will be in a zip file so it will need extracting before you can execute the exe file.
Regards.
Jun 30, 2010 | Microsoft Office Professional 2007 Full...
I have an Epson Work Force 600 wireless printer. It worked once or twice after my son set it up but it hasn't worked since I have read the instruction guide and tried all the help things and have tried...
I had the problem after changing ink on an RX650. After repeated installations of the driver the printer will not work. After many attempts I found that there were jobs scheduled in the queue. When I deleleted all the jobs in the queue the printing restarted but my scanner still won't work.
I am beginning to lose confidence in Epson. The last printer I bouught printed about 28 pages. When I upgraded to Windows XP I could never find a driver for the printer. Had to throw it away on rubbish collection day. Phoning Epson was no good. They referred me to Harvey Norman who referreed me to others.
Dec 15, 2009 | Epson Office Equipment & Supplies
Epson stylus dx4450 lost
try to reinstall the driver properly and try it again. Sometimes the installation of program is cause of those problem.
Jun 16, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson 9500 Print head is not working
hello
I was wondering if you have solved the problem.
If not, please contact me and I will let you be satisfied.
Jack
E-mail:inkbiz@szprintmedia.com
MSN:Jack_yu0813@hotmail.com
Apr 06, 2009 | Epson Office Equipment & Supplies
Computers & Internet Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
