Question about GE Refrigerators
General electric model tpx24prya fridge feezes
It freezes things in the fridge
4 Suggested Answers
SOURCE: Fridge Feezes
My Candy fridge freezer done the same. After a bit of investigation, I found that the little plastic shaft from the front temperature dial that connects to the thermostat has snapped. I merely glued it back together and it worked fine.
In essence, the thermostat was turned on to super all the time, and turning the dial anti-clockwise did nothing as it wasn't connected to the thermostat.
Very flimsy I say.
Posted on Sep 22, 2008
  • 1218 Answers
SOURCE: I need wiring diagram for our General electric Fridge Freezer
I don't like the idea of someone just recharging a system without knowing what's truely wrong.
At this point, based on what you've said, I strongly recommend you call G.E. factory service or a dealer with a qualified service tech in the G.E. line.
G.E. has made the use of a lot of solid state boards, which may well be some if not all of your problems. It will be pricey, but a refrigerator is not a toy. I would advise the tech as well, that you had a recharge performed, and let him follow up on it.
Sounds like whoever worked on your machine isn't well qualified to service it. Newer G.E.'s can be a real bear. Sorry....
Posted on Oct 20, 2009
heatman101
  • 43501 Answers
SOURCE: freezer compartnment is not feezing the food
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 27, 2010
My kenmore coldspot mode 106.53394300 is freezing items in the fridge
If further adjustments cannot be made to the thermostat, the next step would be to replace the thermostat or if so equipped, the temperature thermistor.
Jan 30, 2015 | Kenmore Refrigerators
My PTB19BBGRW Maytag freezer freezes water but is not as cold as it should be. The rest of the fridge is ok?
Could be anything! Clean/ check condenser grille and fan, door seal, fan inside etc. If all else ok, may be short of refrigerant
Aug 08, 2012 | Refrigerators
MY Fridge is over cooling. Things in the refrigetor is getting freeze
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 13, 2011 | General Electric GE Profile Energy Star...
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
FREEZING REFRIGERATOR
Hello Pam, Welcome to FixYa. In actuallity most fridges whether they are side by side, conventional top mount, or bottom mount, the control for the fridge section is nothing more than a damper which allows or prevents air flow through the fridge section. The thermostat which control the "run time" or actual temperature is the freezer control. It is possible to set the fridge control at "1" and yet still have items feeze because the freezer control is set to "3", "5", or higher. Try adjusting the freezer control to a lower number as well and see what that yields. You may also want to vacuum out your condensor coils under the unit...( unplugging the power cord first of course ;) safety first ) this too can cause items to freeze in the fridge section. Without getting too deep into how it all works I'll just say it effects the entire system negatively. Hope you find this an acceptable solution and can take a moment to rate it accordingly. Thank you for visiting FixYa and please let me know if you require further assistance. macmarkus :)
Jul 12, 2010 | GE GSS20IEP Side by Side Refrigerator
It will not pull up when i try to login. the feeze keep popping u
What is the best thing to do when your screen freezes up?
Aug 04, 2009 | Facebook Social Network
H/p is freezing up. and acoil is freezing up.w
Two things cause freezing of the coil, lack of charge or lack of airflow, filters, coil and blower assembly all need to be clean, the thermostat will not cause feezing as it is strictly an on off control for convienience
Jul 19, 2009 | Whirlwind FH-778 Air Conditioner
My side by side fridge, fridge side is feezing up...
HI,GOOD JOB CLEANING THE COILS IT HELPS ALOT,MOST TIMES IF YOUR FREEZER SIDE IS FREEZING UP THERE ARE 5 THINGS TO CHECK,WHAT MAKE,MOST GE HEARTERS GO BAD FIRST,EASTEST TO CHECK FIRST IS THE FAN,OPEN FREEZER DOOR,IS THE FAN RUNNING,SOME MODELS YOU WILL HAVE TO HOLD THE FREEZER BUTTON DOWN FIRST,MOST ON INSIDE TOP,NEXT REMOVE FREEZER BACK PANEL WALL,IF YOU SEE A SHEET OF ICE,YOUR DEFROST HEATER(ON BOTTOM OR SIDE) AND THE HEATER TERMANATOR(LITTLE ROUND CLIP ON BALL WILL HAVE TO BE CHECKED WITH A OMES METER,YOU CAN DEFROST IT WITH A HAIR DRYER,WHEN DEFROSTED YOU CAN SEE IF THE DRAIN(MIDDLE BOTTOM OF FREEZER IS CLOGGED,LAST DEFROST TIMER(TOP FRONT,BACK BOTTOM,INSIDE FRIG.TURN CLOCKWISE SLOW TILL YOU HEAR A CLICK,SEE IF FREEZER FAN WENT OFF,WAIT 25 MINUTES,SEE IF FAN COMES BACK ON IF SO IT'S NOT THE TIMER,LET ME KNOW WHAT YOU FIND AND I WILL HELP YOU FARTHER-MIKE
Jun 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge Feezes
Very flimsy I say.
Apr 08, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
