Question about Maytag Dryers
Dryer belt routing on Maytag dryer model MDET236AYW
No way to tell how the belt goes on as you are unable to see what you are doing. A diagram should be available. Company itself not helpful, except call a repairman. I have owned and replaced belts before with little or no difficulty, but this one has got me. Model MDET236AYW.
Thanks
Jim
  • Teddi B May 11, 2010
    Yea I thought I would find it here, but no. You'll have to post a picture some where and let me know.
With the drum removed, loop the belt around the drive motor an run both strands of the belt under the tension pulley. You have to be carefull on getting the drum back in place while working the belt back on a LITTLE AT A TIME. Once installed verify the belt is not caught on anything and you should be good to go.
Mark
Posted on Aug 11, 2009
I need a diagram of how the drum belt is installed on a maytag centennial dryer. Mine came off and I don't know how to put back on.
Hi c ellerts..
Here is the picture of the routing of your Maytag..
You can get this at the following wepage
Please take time to rate me thumbs up
http://www.expertappliance.com/dryerbeltconfiguration.html
Sep 12, 2011 | Maytag Dryers
Tip
Maytag Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For all single belt models use this diagram:
Style: Flat with ribs
Installation Tips: Flat side of belt against drum
on Mar 06, 2010 | Dryers
Need SDE305DAYW dryer belt routing diagram. Please help
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Scroll down and you'll find the maytage diagram. There are many, but it's about half way down.
Good luck, it might help to have a buddy help for an extra set of hands.
Mike
Aug 04, 2011 | Maytag PYE2300AY Electric Dryer
I need a diagram on how to route the belt on a maytag atlantis dryer model number mde7600yw and also a diagram of the tensioner spring for the tension pulley
Hi and welcome to FixYa, I am Kelly
The flat side of the belt goes against the drum and the routing diagram can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
If you need more assistance after viewing the diagram and attempting to install your belt without success, just respond here and I can help you.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
Drum Will not turn
you probably have a broken drum drive belt. They are not a difficult do-it-yourself job.
Your local appliance parts outlet should have the belt.
Jun 13, 2009 | Maytag Dryers
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer belt replacement
maytag.gif Diagram E
Jan 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
1,954 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
