Hitachi TV flickering on startup
Hi Guys. I have a 32" hitachi LD30U tv which ive had for around 4 years. When i switch the TV on the screen distorts between a scrambled blue screen and a normal screen. Kind of flickering. After around 10 to 15 minutes this stops and the tv works fine and is fully functional. Not sure if it`s on the way out. I`m hoping there is a simple solution which i`m overlooking. Any help would be greatly appreciated. Tom
wyoed1
  • 211 Answers
SOURCE: hitachi 57f710s
Sounds like a video board problem. May also be the convergence board. You might get some freeze spray ( a component cooler that comes in a spray can ) and while the set is on, spray the boards and see if the problem temperarly corrects. This is to isolate the problem. Once the problem is isolated, you can change the bad component. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
ctf1800
  • 4402 Answers
SOURCE: blue haze on hitachi 51" tv
http://www.hdtvoice.com/voice/showthread.php?t=15263
Posted on Jan 14, 2008
SOURCE: Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Posted on Feb 01, 2008
  • 579 Answers
SOURCE: Hitachi 51SWX20B's screen has 3d effect
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Posted on Feb 15, 2008
charcois
  • 763 Answers
SOURCE: hitachi 60vs810 blue screen only no other functions but on, off
try to pull the power plug for about a couple of minutes and after that turn it on. see also the settings of your tv and manual of it. if all suggestions here didnt fix your problem then you might send it to repair service. hope that helps!
CHARCOIS
Posted on Sep 30, 2008
Startup problem Hitachi 32LD30U
It sounds that the main power regulator board has the fault. Try by replacing the electrolytic capacitors there. These capacitors can deteriorate its value with time. As the set is about 4 years old, this might be the fault. If it do not help you, replace the power regulator board as card basis. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Check the site in 'Mosaic' view.It will make search easy.
Jan 02, 2014 | Hitachi Televison & Video
Have a 50fx48b Hitachi TV and screen flickers and then goes to small wavy horizontal line. smack tv and it goes back to normal.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Hitachi C50-FD2000 Screen Distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jan 02, 2009 | Hitachi C50F200 50 in. Rear Projection...
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Green picture and distorted
Mar 11, 2008 | Hitachi 42V710 42" Rear Projection HDTV
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Pink Screen
There is a service bulletin for this problem - you need to reintialize the memory settings in the service menu - I have a pdf file showing how to do this.
Sep 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
