Indesit iwb6113 stops at rinse stage and all lights flashing green on front panel
  • 1294 Answers
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Posted on Jun 16, 2007
SOURCE: flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
Posted on Oct 25, 2007
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
aardvarkrepr
  • 62 Answers
SOURCE: indesit WIDL1265 flashing lock, rinse and timer
Hi
Problem possibly caused by blockage in drain pump filter. If you remove the bottom plynth you will find a black screw cap (about 2" diamiter). BEFORE you unscrew you will have to make sure you have plenty of towels and low bowls because all the water from the drum will flood your kittchen if you unscrew!!!
How I do it is that i (with someones help) try and pull the washing machine out . Then i tip it up 45 degrees With someone holding the washing machine I place plenty of towels underneath the washing machine and SLOWLY open the filter.
I bowl will catch a lot of water but it will still be messy.
When all the water has drained pull the filter out completely and you will probably find all sorts of debris there.
If the filter is clean look inside the filter body just in case there is a coin or two there as these will jam the drain pump and stop it from draining.
Hope this helps
aardvark Repairs
Posted on Nov 16, 2009
SOURCE: all lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Posted on Apr 19, 2010
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Why doesn't it go past the "pre-rinse" stage?
I would say that there's a very high probability that the heater in the machine has failed. It does the cold pre-rinse but when it gos to the next stage and tries to engage the water heater it detects an open circuit and faults out. You will find replacement heaters on eBay and probably videos on how to replace on YouTube
Sep 15, 2015 | Hoover Washing Machines
Whirlpool Front Loader WFS1071BW, rinse cycle problem
I had exactly the same problem with the same machine... I've seen a few people on various forums with the same problem. The problem on mine turned out to be just the EMI filter located next to the power cord inlet. I just bypassed it for now until I can get a replacement.
Apr 26, 2013 | Washing Machines
Ge washer gtwn3000mows doesnt get water spin or rinse
Remove the front panel. The motor will have a green light flashing error codes. Count the flash sequence and post it back.
Nov 22, 2012 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
