Question about Magic Chef Microwave Ovens
Help buying and replacing power cord for MCM770B
I am not able to find the power cord anywhere, would you know if anybody sells it? Also, I can use some help( steps if possible ) to replace the power cord. I am hoping it would be simple and I wouldn't have to take my microwave to a professional. Thanks!
Surface light no longer works
You might wanna check appliancepartspros.com for the part or even check out ebay once you know the part number.
And if you get another nuker I would not get an LG after the way they have helped you!!!!!!!!!
Aug 22, 2015 | LG Microwave Ovens
I only ned the bowl for my stircrazy popcorn popper. Is it possible to buy one and the cost please.
We can't sell you the bowl at Fixya as we only can help with instructions and so on. What I can help you with is where and who to contact about the bowl.
I believe your popper is made by WestBend. So you have a couple of choices. You can look for a repair shop that will have replacement parts. These are not that common these days but they are around. You can search on the net for them and I would talk to the store you purchased the popper from and ask where you can get parts. They may have a local repair depot that will be able to help. If that doesn't get you a source then you need to try Westbend.
Go to http://westbend.com/ and click on the support tab. Then click on replacement parts then Westbend and then popcorn popper. Select your model and it should now display all available parts. Unfortunetly the replacment parts tend to be power cords and covers so there may not be a bowl available for your model. It is still worth using the Westbend contact information and asking if they have one just in case.
Aside from other sources such as ebay or thrift shops you may not be able to find a bowl. And what you have to keep in mind is the replacement cost of the bowl plus shipping if you can find one. You may find that you will have to buy a new popper as it would cost less than getting the bowl.
Sep 18, 2011 | Microwave Ovens
I need to replace the existing 3-phase (with 4 prongs) lead on my (old) defy 621s stove with a single-phase lead (with 3 prongs) as my flat is not able to support 3 phase power. Can anybody tell me how...
This is for a dryer but the range is the same...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 30, 2010 | Microwave Ovens
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
Chipping/peeling rusting paint in interior under carousel
Scratches and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord and remove the turntable and the support that is under the turntable. Clean the surface of the support wheels or any other part that rubs on the oven cavity.
May 11, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Why wont it power on?
probably a burned out fuse.
unplug it, open the case, and trace the power cord. There is usually an in-line fuse before the cord attaches to the main transformer.
buy a replacement in the hardware store, look for an old-style automotive fuse.
Oct 20, 2009 | Emerson MW8985W Microwave Oven
My microwave wont even power on do you think it is a fuse
Almost always. The fuse is usually in-line with the power cord.
Unplug it, and trace the power cord. There will usually be a small automotive type in-line fuse before the cord attaches to the main transformer.
Once you see the fuse, you will be able to find a replacement. They are very cheap, you can usually buy 5 for a few dollars.
GE Microwave - Power Cord Appears to be Dead
Most microwave ovens are equipped with an internal fuse. This is typically located where the power cord enters the cabinet. The cabinet will have to be opened to verify the fuse.
The magnetron is not directly attached to the power source, it has to be stepped up in voltage significantly, either through a transformer or inverter.
It is usually best to have professional tech check the fuse for operation. Most shops will do this for a small fee if you drop the unit off yourself.
Jul 28, 2008 | GE JE1860 Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
