Question about Kenmore Dryers
Kenmore Elite stem dryer #796.8107, 796.9107
Okay, how do I remove the lower panel safely to get to the 2 metal in lint trap?
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Posted on Feb 11, 2009
  • 77 Answers
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Posted on Apr 20, 2009
  • 89 Answers
SOURCE: Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
Posted on May 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
How do I remove the front oanel of the Kenmore Elite dryer model #796.8107, 796.9107?
Hello, You can look for aditional information in following web page http://www.searspartsdirect.com/repair-help.html?SID=MMLxSplashPage . Please try it, it could be helpful for You. Sincerely 1_27_2014_4_37_18_am.png
Jan 02, 2014 | Dryers
My kenmore elite dryer that i bought 2 years ago lint trap corner is catching my clothes and tearing them. we had it replaced and its doing it again. I am tired of messing with it. Please help.
don't know if you already had this fixed,usually this is caused by not having your dryer cleaned out,the lint builds up inside the duct that the lint filter slides down into and has to be removed and cleaned out.also in some of the kenmore dryer ducts there's a metal clip inside the duct that can come loose and hold the lint filter up.these are the two most likely causes for this to happen.
Sep 23, 2013 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite digital dryer, manufactured in 2002, and it will run for awhile but then it stops and sets itself to a certain dry time/settings and wont do anything else. When I press stop, it just...
I have a newer model of what I believe is the same dryer. I'm not sure if the layout is the same on yours as it is on mine.
I had the same problem, first the problem stems from user error -- there's a reason they say to empty the lint trap after every use. I know I've been remiss in emptying it thus my beeping bonanza.
Second -- THE FIX -- in the lint trap area (this is described based on my 2007/08 model) there are screws that allow you to remove the lint trap censor cover, unscrew, you'll see it's connected to wiring, there are 2 electrical connections, these slide on and off, gently pull and each will slide off, clean the connectors. By disconnecting to clean, which is the basis of the problem, the electric function resets (as far as I know), the beeping stops and you're good to go! Good luck.
Aug 20, 2010 | Kenmore Dryers
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
remove lint trap
unplug unilt
May 25, 2009 | Kenmore 62602 Electric Dryer
Small plastic toy down lint trap
is the lint filter on the top of unit??? if so you ll need to disconnect power remove the 2 phillips head screws under the lint trap holding it to the main lid. then after removing about 10 1/4in screws from back panel you ll see a metal sleeve running down the back of the unit( the lint filter actually slides in to it) ending in a circular shape below. remove perhaps 4 more screws holding that panel on and youll gain acess to retrive whatever has fallen down there. easy enough to do yourdself no need to call in a professional
Oct 23, 2008 | Dryers
Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Mar 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer
unplug unit/dicnnect power. 3 1/4in screws will remove lower panel, allowing access to remove lint(if excessive amount i would also have venting cleaned and or replaced.
Feb 21, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
