Question about Dell Inspiron 1501 Notebook
When I press the up and down button to adjust the brightness, it only adjusts a little bit. This started when I had the monitor replaced. Is there a fix?
  • dbbell2588 May 21, 2009
    I have pressed it repeatedly. The window pops up to show dark or light. The adjustment bar moves completely from left to right but barely adjusts the brightness. I have a very hard time seeing the screen when I use my laptop in the car. (not while driving of course)
  • dbbell2588 May 28, 2009
    Thank you very much!
  • Dell Master
  • 13,433 Answers
Since its a diffrent monitor with diffrent parts, the adjustment may have a higher or lower effect on it. unless its the exact match with the old one then it should work the same as the old one.
you have tried pressing the buttons repeatedly to lower it more?
Posted on May 21, 2009
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
I purchased my Norcent computer monitor four years ago. Now, the sub-menu Contrast/Brightness selection keeps popping up on my screen. So, I have to either push the #1 button to Exit or the #2 Adjust...
It seems to be a hardware issue with the buttons. They are stuck or the rubber cushion under the button has gone bad. That's the reason they are getting pressed automatically. You may take to a local store for a small repair.
Regards,
Shrey
Jun 04, 2011 | Norcent Technologies LM-965W 19" LCD...
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
MY SCREEN IS TO BRIGHT
On your monitor there should be a dial or button that you can use to adjust the brightness to your satisfaction. The icon is usually represented by an image of the sun.
Hope I helped
Nov 27, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
Hello how to adjust brightness on an ACER 19" LCD monitor? thank you Kurt
1. Press the MENU key.
2. Press the < or > key to select the BRIGHTNESS icon from the menu (looks like a little sun).
3. Press the MENU button again to enter the BRIGHTNESS menu.
4. Use < or > to select appropriate brightness.
5. Press MENU button to exit.
5. To exit - select the EXIT function from the menu and press MENU button again.
Apr 01, 2009 | Acer X193W LCD Monitor
LG 19 in monitor
it would be helpful to know which monitor you have - each one is a little different... basically, you need to press the "menu" button on your monitor, use the arrow buttons (on monitor, not keyboard) to get to the brightness adjustment screen, hit set, then adjust with arrow buttons, and hit set again, then menu to exit.
Jul 14, 2008 | LG L1915S 19" LCD Monitor
Samsung 731N Auto Adjustment
I'm having the same problem. Started three days ago. Really annoying. First I downloaded a driver because that was reccommended over plug and play. But that did not fix the problem. I ended up pressing the menu key (1st on left) and while holding it down I wedged a little piece of paper to hold the key down and the popup menu's have stopped. The box can be the brightness/contrast or auto/image reset/color reset ...
it doesn't matter, they all popup after pressing buttons left and right. Have no answer to correct the problem but at least I can now compute without these stupid menus.
Dec 27, 2007 | Computers & Internet
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Dell Inspiron 1501 Notebook Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
