Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
No Gas to Primer Bulb
Bulb has collapsed and motor will not start
  • cdog53 Jun 01, 2009
    Jim, yes and no. I took the carb apart and cleaned it, Didn't run but it was dirty. Then I found a broken fuel line in the gas tank so I replaced that. Started right up ran for about 10 minutes then stopped. Looks like I need to replace both gas lines with the proper size. No place around here (Rochester NY).carries them so I'll have to order those and I will get the carb kit as well. Thanks for pointing out where the problem was.
    craig
  • 1,041 Answers
It sounds like the carburetor needs cleaned. Take the carb. apart and clean it with carb. cleaner. Use a Den Tech Brush, (used for cleaning teeth), they are perfect for cleaning the small ports in carb. If that still doesn't work, you may need to buy a carb. kit for your weed eater. If so, replace the gaskets and valve needle, and also make sure to replace the small screen. this should all come in the new carb. kit.
Posted on May 22, 2009
  • Jim Parker
    Jim Parker May 31, 2009
    Did this solve the problem?
    Jim
  • Jim Parker
    Jim Parker Jun 02, 2009
    Thanks for the rating Craig. If you should have any questions on drywall finishing/patching, or know someone who does, put yuor questions to Tools-Building & Power-Hand Tools at FixYa.com
    Thanks Again,
    Jim
Primer bulb won't recover
Your lines are crossed on the primer bulb. You probably have the return line going to the fuel filter in the tank.
Jul 20, 2014 | Poulan Garden
Primer bulb collapsed
Slightly unscrew the gas cap and see it the problem goes away.
Many times the Gas tank Vent clogs and this will cause the engine to create a vacuum in the gas tank until the engine can't draw in the gas .
Jul 15, 2013 | Garden
Bulb on primer collapses. which line in gas tank does the filter go on?two tubes in tank one goes to bulb other goes to bottom of carb which one gets the filter, it fell off
The line that goes to the bottom of the carb has the in-tank fuel filter. That is the fuel supply, the one coming out of the primer base assembly under the bulb is the return line. That line carries air mixed with old fuel back to the fuel tank when the bulb is pushed.
Jun 11, 2011 | Poulan Garden
Troybilt trimmer primer bulb collapses. it will start occasionally but will only run a few minutes.i have replaced the primer bulb and gas lines and still have the same problems.
it should have a small vent in the fule tank cap if its blocked the primer bulb will be sucked in as the fule pump can **** any fule from the tank
check the tank cap first,,,,,
Aug 08, 2010 | Troy Bilt Tb70ss Gas Trimmer
Replaced primer bulb and gas lines will not prime or start
Sounds like you have the lines connected incorrectly. Make sure that the bottom of the carb is connected to the inlet side of the primer (take the lines off and with one of the ports covered with your finger push the bulb, if it collapses and doesn't return then that's the suction/inlet of the bulb). The other side of the bulb needs to be connected to the gas tank. The other side of the carb needs to go to the filter side of the gas tank.
Nov 04, 2009 | Garden
I need to replace the gas lines The lines fell apart unsure were the parts go were can I find a diagram of the gas lines
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel line connection
Fuel filter to bottom of carb. The suction port of primer to the top of carb outlet line to other port to tank.
To tell which port is outlet put your finger on one port and push bulb if the bulb collapses and doesn't return then that is the inlet (suction) side.
Good luck
Aug 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Routing of fuel lines for a weedeater bv200 type 2. Which lines go where from the carb into the tank?
The line with the filter goes to the bottom of the carb. The other line goes to the outlet side of the primer bulb and the other line from the primer bulb goes to the top of the carb (The primer sucks gas through the carb).
Ps. if you are not sure which nipple of the primer is the outlet port then put your finger on one of the ports and push the bulb. If the bulb stays ridged then that's the outlet and if it collapses but doesn't fill but up then that's the inlet side.
Jul 10, 2009 | Garden
My weed eater will not start
Sounds like the carb or gasket around the carb is leaking allowing the pressure to blow by when you press the primer bulb. If its not air tight it will not pop back out. Check your carb and surrounding gaskets and check for a leak.
joe
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
I have a chainsaw carb problem
clean out the two gas hoses with a pipecleaner then check replace the in-tank fuel filter if the carb still does not recieve gas your fuel float in the carbretor is not rising to let in the gas this will require disassembly of the WT324 carbretor
Apr 28, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
892 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
