Connect player How do I connect a quick browZer media player to the remote stick on my steering wheel of a laguna car?
2 Suggested Answers
  • 140 Answers
SOURCE: renault laguna power steering connecter leaking
YOU HAVE A POWER STEERING HOSE LEAK, YOU SHOULD BE ABLE TO REPLACE YOURSELF FOR ABOUT $30.. GO AHEAD AND REPLACE BOTH HOSES, THERE WILL BE A PRESSURE HOSE AND RETURN LINE..THIS SHOULD FIX YOUR PROBLEM..GOOD LUCK KEITH...
Posted on Mar 12, 2009
How to put a laguna radoi code in
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don`t have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed Press the Second Preset Button repeatedly for the 2nd digit to be displayed Press the Third Preset Button repeatedly for 3rd digit to be displayed Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code ) ============================================================
Jun 14, 2011 | Car Audio & Video
Please , show me how to put my radio code in for renault laguna --R534NEV ,
Philips Renault Code Entry (For cars with a Steering WheelRemote Control.) Note: If your car does not have this remote control, thenplease ask for alternative instructions ) Turn on the radio and the display will show 'CODE' Use the Steering Wheel Remote Controls for code entry. Press the [ ¬] button then rotate the thumb wheel for thecorrect first digit Press the [ ¬] button then rotate the thumb wheel for thecorrect second digit Press the [ ¬] button then rotate the thumb wheel for thecorrect third digit Press the [ ¬] button then rotate the thumb wheel for thecorrect fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to storethe code ============================================================
Mar 16, 2011 | Car Audio & Video
Car is parked and off but unable to turn key in ignition and steering wheel is locked.
Try moving the steering wheel left and right as you turn the key - sometimes the steering lock will stick if there is pressure from the wheel. If this doesn't do it, try spraying or pouring some dry graphite into the lock cylinder ( the hole for the key) slide the key in and out of the lock quickly a few times to spread the graphite, then move the steering wheel left and right as you turn the key.
Hope this does it for you!
Nov 09, 2010 | 1997 Chrysler Concorde
I need code for renault laguna 2001 cd player. Model No: 22DC279/62Z ; TOY657 ; RN279FY0017377 ; PROD NO: FD0100510017377
Try code 1312
Jan 18, 2010 | Car Audio & Video
I need to know how to put the radio code into my renualt laguna 02 reg.
Jan 17, 2010 | Car Audio & Video
Hi.. I have a Renault Laguna 1996 2.2 diesel..fitted new battery and radio wont work...tried to enter code, but all i get is CODE..THEN 0000, but using the back wheel on hand lever at steering-wheel...
These are the usual instructions for a Renault with a Steering Wheel Remote Control
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
press and hold the [¬ ] button for up to 10 seconds to store the code
Here is another method if the Steering Remote does not work
These are  the working Code Entry Instructions if the Renault does NOT have the Steering wheel Remote Control
Keep pressing  the Preset [1] for the correct first digit
Keep pressing  the Preset [2] for the correct second digit
Keep pressing  the Preset [3] for the correct third digit
Keep pressing  the Preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the Preset [6] to save it.
Dec 01, 2009 | Car Audio & Video
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
2003 Renault Laguna 1.9Dci - steering wont unlock - cannot start
Hi this was exactly the problem i had with my Laguna 1.9dci its a sensor switch on the steering column. Cricical circuit to the car. so will not run without it. afraid you will have to replace the sensor. had to get renault to do mine.
Jan 28, 2009 | 2004 Renault 181
Wii mario kart, second wheel won't turn
I tried resyncing from the main screen, but one of the wiimotes still didn't work. I read to smack the wiimote facedown in your hand a couple of times, and that worked!!!
Apparently the motion sensor can get stuck inside, although it doesn't totally make sense, because previously when the wiimote didn't steer, it still moved on the screen to choose character, car, etc.
Dec 25, 2008 | Nintendo Mario Kart (Wii) for Wii
KVT-729 car DVD player
The steering remote control input is for a wired remote control, or a third-party interface that allows you to adapt vehicle steering wheel controls to operate your deck. Your problem is the parking sensor wire. This is supposed to be connected to your vehicle's parking brake switch. It detects when the brake is set, and will prevent a picture from showing when it's not set. The intent is to prevent you from watching movies while the vehicle is in motion. If you can get a good look at the parking brake mechanism, you should be able to see the brake switch. Usually there's a single wire coming from the switch, which is built onto the parking brake mechanism. Connect your parking sensor wire to the wire coming from this switch.
Jul 30, 2007 | Kenwood KVT-617DVD Car DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
