Question about Craftsman Garden
Managemylife com sears
Snow blower want start carftsman model number 247887790, starter is turning over there is gas in the tank blower 3 years old and can t find owner manual. please help us... thanks
  • 666 Answers
SOURCE: would like owners guide and parts manual
Go to following site
www.echo-usa.com/documentation.asp?Model=pb210e&lang=E
Posted on Mar 24, 2009
slohry
  • 87 Answers
SOURCE: I need an owners manual for a Sears Blower/Vac Model #517.797940
Have Mod and ser #'s available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
extroitive
  • 35 Answers
SOURCE: Need owner manual for McCulloch Titan PB 250 Blower
Try here I have had good luck with them
www.mcculloch.manuals-in-pdf.com
Posted on Apr 18, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
pippall
  • 1486 Answers
SOURCE: Hello, I have a Poulan Pro 25cc gas blower, 1 -
Remove the spring loaded screw.Then clean the end of it.Replace it.Screw it in tight and then losen one and a half turns.hope that was helpfull.
Posted on Aug 01, 2009
I have a Craftsman Snow Thrower model # 247.881731. At the end of last year I drained the gas as recommended in the manual, this year I filled it with fresh gas and it now has a problem starting. I pu
Draining the gas from the tank doesn't drain the float bowl in the carburetor. It still had last year's gas in it. Gas will start to turn to varnish if left sitting 6 to 12 months. You'll probably have to remove the carburetor, disassemble it and clean it out with Gumout carb cleaner or some similar product.
When you get it running and the snow's over and done with, put some Stabil in the gas tank to prevent the gas from converting to varnish and then start it up and run it until that stabilized gas is through the carburetor and into the engine. You can leave it with the treated gas in the tank.
Feb 01, 2015 | Craftsman Snow Blower 26 In. 208CC...
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
I have a sears 247 889571 24" snow blower. Start fine. Runs rough, like the choke is on. Choke is off. Fresh gas (ran it dry last spring). Ran 1 tank through with it running very rough. Just as it ran out...
You ran it dry at some point. Gas tanks collect crud and water at the bottom over time and this may have been sucked up into the fuel filter or carb. Clean or replace fuel filter, then remove and carefully strip apart and clean all parts of the carb be gentle with brass and any moving parts in the carb, clean with plastic tools.
Dec 14, 2013 | managemylife.com
Carb gummed up
Try ordertree.com , amazon or sears.
Nov 08, 2013 | managemylife.com
Snow blower/starter handle will not pull
Here are some ideas:
Can you find a warmer place to put it temporarily, so it can warm up?
If not, can you put some sort of a heat lamp on the crankcase or battery until thew are warm to the touch?
Take the spark plug out of it.
Get a little thin oil, like 3-in-1 oil or sewing machine oil, or WD40 and put a little ( teaspoon) in the spark plug hole to lubricate the piston rings. Now try to get it to turn over with the plug out.
Watch out for that oil blowing out of the hole!
If it will turn over, you are half-way there.
If not, sounds like the engine is frozen up, might require being taken apart :-(
If it will turn over, put a teaspoon of fresh gasoline in the spark plug hole, and reinsert the spark plug and try it.
A little starting fluid might help.
Remember to use Sta-Bil or Sea-Foam or some such gas treatment if your blower is to sit for a long time unused, or the gasoline will go sour. .
Be blessed
Jan 28, 2013 | managemylife.com
I need a replacement belt for my craftsman snow blower the model # is 886640 24" 5.0 What size belt do I need? Thanks
Sears will not tell you what size of belt you need. They only list parts by part number. But this machine uses MTD belts and you can get them at searspartsdirect.com or your local mower shop can order them through MTD.
Part Listing: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/Model-247886640/0247/1507200?sid=MMLxMerchandizexManualsModelxcraftsman%2088664x247886640
Manual: http://www.managemylife.com/mmh/owner_manuals/search?query=craftsman+88664
Here are the two part numbers for the two belts on the machine. MTD Part #: 954-0343
and #: 954-0430B
Any other questions, please ask. Remember to rate this answer if it helped.
Jan 11, 2011 | Craftsman Garden
I would like to download the manuel for the craftman 5hp snowblowermodel # s247.996640
The model number of your snow blower is actually 247.886640. That's why nobody else could figure where to get your manual.
Here is the link to the manual:
http://www.managemylife.com/mmh/owner_manuals/25129/CRAFTSMAN-Snowthrower-Gas-L0308228?brand_name_search=247.886640
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Dec 28, 2010 | Garden
I have a craftsman snowblower that I believe is about a 1998-99 model. I need to know what type of oil it uses... If it does at all.
I can answer this for you if I have the model number of the snow blower. But, if the snow blower uses a 2 cycle motor it will use an oil/gas mix and no oil in the crankcase. If it is a 4 cycle motor it uses oil in the crankcase and none in the gas.
The easiest way to find what type of oil it uses is to look in the operators manual. To get the free manual go to managemylife.com and input your model number in the manuals tab.
Your model number is located on the machine and looks like 247.123456.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Dec 17, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Need to find an owners manual to install 42" snow
I have to assume you are trying to install a newer blower made in the last five years to the GT 5000.
Two ways to get the manual. But you need the model number off the snow blower attachment itself. The blower is made by Agri-Fab.
First way. managemylife.com. Click on the manuals tab, put in your model number and get your free manual.
Second, if you can't find it on managemylife.com. http://www.agri-fab.com/manuals.aspx. Push the "click here" in the middle of the page to go to the manuals section. If you are having problems call the 800 number on the top of the screen.
Dec 13, 2010 | Craftsman GT 5000 26 HP54" Garden Tractor...
Garden Logo
561 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
