Question about Saws
Performance 254mm .FMTC1500TK
Missing pulley retaining bolt
    Champion:
  • 279 Answers
Contact the manufacture or a local True Value hardware
Posted on May 07, 2014
How do you remove the crankshaft dumper pully?
Published: 11-May-2011
Engine - V8 4.4L Petrol - Crankshaft Pulley
In-vehicle Repair
Special Tool(s)
Holding Tool Crankshaft Pulley
303-893(LRT-12-080)
Adapter
303-191-03
Bolts and spacers
303-191-04
Remover, crankshaft pulley
303-588
Remover, crankshaft seal
303-D121
Installer, crankshaft seal
303-1100
Adapter - Crankshaft seal installer
303-1100-01 Removal
  1. Disconnect the battery ground cable.
    For additional information, refer to: Specifications (414-00 Battery and Charging System - General Information, Specifications).
  1. WARNING: Do not work on or under a vehicle supported only by a jack. Always support the vehicle on safety stands. Raise and support the vehicle.
  1. Remove the accessory drive belt.
    For additional information, refer to: Accessory Drive Belt (303-05B Accessory Drive - V8 4.4L Petrol, Removal and Installation).
  1. Remove the cooling fan shroud.
    • Release 2 clips from the cooling fan lower shroud.
    • Release and remove the cooling fan lower shroud from the cooling pack.
  1. Using the special tools, retain the crankshaft pulley.
  1. CAUTION: Under no circumstances should the crankshaft setting peg, 303-645, be used in the following operations, to restrain the crankshaft. NOTE: The crankshaft pulley retaining bolt will be very tight.
    Remove the crankshaft pulley retaining bolt.
    • Discard the bolt.
  1. Remove the special tools.
  1. Using the special tools, remove the crankshaft pulley.
    • Collect the locking ring.
  1. Remove the special tools from the crankshaft pulley.
  1. Using the special tool, remove the crankshaft front seal.
    • Remove the outer section of the seal.
    • Repeat the process to remove the inner section of seal.
  1. Check the crankshaft damper pulley and locking ring for damage.
Installation
  1. Clean all the crankshaft pulley mating faces.
  1. Using the special tools, install the crankshaft front seal.
    • Lubricate the seal with clean engine oil.
    • Use the discarded crankshaft bolt with the service tool.
  1. Install the crankshaft pulley.
  1. Install the crankshaft pulley locking ring.
  1. CAUTION: The screw thread in the crankshaft pulley must be cleaned out before installing a new crankshaft pulley bolt. Install, but do not tighten, the new crankshaft pulley bolt.
  1. CAUTION: Under no circumstances should the crankshaft setting peg, 303-645, be used in the following operations, to restrain the crankshaft. Using the special tools, retain the crankshaft pulley.
    • Tighten the crankshaft pulley bolt to 380 Nm (280 lb.ft).
  1. Install the cooling fan lower shroud.
  1. Install the accessory drive belt.
  1. Connect the battery ground cable.
Jan 27, 2016 | 2006 Land Rover Range Rover Sport
How do I replace the power steering pump?
Hi Brian:
Check this REMOVAL and INSTALLATION procedure... (see Figures 2, 3 and 4)
  1. Position a fluid catch pan under the power steering pump.
  2. Disconnect the feed and return hoses from the power steering pump, then drain the excess fluid into the catch pan.
On models equipped with a remote fluid reservoir, disconnect and plug the hose(s) in order to prevent system contamination or excessive fluid loss.
  1. Remove the drive belt from the pulley.
  2. Install a puller tool such as J-25034, or equivalent onto the power steering pump pulley. While holding the pilot bolt, turn the tool nut counterclockwise in order to press the drive pulley from the pump.
When installing the puller tool onto the power steering pump pulley, be sure that the pilot bolt bottoms in the pump shaft by turning the head of the pilot bolt.
Fig. 2: Installing the pilot bolt
Fig. 3: Removing the power steering pump pulley
Fig. 4: Installing the power steering pump pulley
  1. On most models, it may be necessary to unplug the electrical connection from the A/C compressor, unfasten the compressor mounting bolts and set the compressor to one side without disconnecting the lines.
  2. If equipped, unfasten the power steering filler tube bolt and remove the filler tube.
  3. Remove the rear brace retainers and the brace.
  4. Remove the power steering pump-to-bracket bolts and then remove the pump from the vehicle.
To install:
  1. Position the pump to the vehicle and secure using the front retaining bolts to 22 ft. lbs. (30 Nm) 2.2L engines. (50 Nm). On 4.3L engines tighten the bolts to 37 ft. lbs. (50 Nm).
  2. If equipped, install the rear brace and tighten the retainers to 22 ft. lbs. (30 Nm) on 1994-98 2.2L engines. On 1999 2.2L engines, tighten the brace retainers to 37 ft. lbs. On 1994 4.3L models tighten the retainers to 24 ft. lbs. (33 Nm). On 1995-99 4.3L models, tighten the retainers to 31 ft. lbs. (41 Nm).
  3. If removed, install the A/C compressor.
  4. If removed, install the filler tube and its retainer. Tighten the retainer to 15 ft. lbs. (20 Nm).
  5. Use a pulley installer such as J-25033 or equivalent to press the drive pulley onto the power steering pump. While holding the pilot bolt, turn the tool nut clockwise in order to press the drive pulley onto the pump. Check that the pulley is flush within 0.010 in. (0.25mm) of the shaft end.
When positioning the installer tool onto the power steering pump pulley, be sure that the pilot bolt bottoms in the pump shaft by turning the head of the pilot bolt.
  1. Properly install the drive belt and, if applicable, adjust the tension.
Be sure to secure any hoses which may get in the way or rub other components.
  1. Remove the caps, then connect the feed and return hoses to the pump.
  2. Properly refill and bleed the power steering system.
  3. Test drive the vehicle.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 08, 2012 | 1996 Chevrolet Blazer
How do you aline the timing marks on the cam and crank on a 97 toyota camry with a 2.2
Hi, the procedure is pasted below. There is a good rundown with pics at the following post:
http://www.toyotanation.com/forum/showthread.php?t=264429
Please let me know if you have questions.
REMOVAL & INSTALLATION
5S-FE Engines
  1. Remove the timing belt covers as previously detailed.
  2. Raise the engine just enough to remove the weight from the engine mount on the right side.
  3. Remove the thru-bolt, two nuts, and right hand mounting insulator.
  4. Remove the retaining bolts and remove the right hand mounting bracket (from the side the alternator was removed from).
  5. Remove the timing belt and timing belt guide. If the timing belt is to be reused, draw a directional arrow on the timing belt in the direction of engine rotation (clockwise) and place matchmarks on the timing belt and crankshaft gear.
  6. Remove the bolt retaining the No. 1 idler pulley and tension spring.
  7. Remove the No. 2 idler pulley.
  8. Remove the crankshaft timing gear , if it can not be removed by hand, use two flat bladed tools to pry it off. Make sure to position shop rags to prevent damages to the components.
  9. Remove the nut retaining the oil pump pulley.
To install:
  1. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  2. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  3. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly.
NOTE Remove any oil or water on the idler pulley and keep it clean.
  1. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  2. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys.
NOTE If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  1. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  2. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  3. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  4. Align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt.
  5. Tighten the set bolt to 27 ft. lbs. (37 Nm).
  6. Turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  7. Install the timing belt and check the valve timing as follows:
    1. Align the matchmarks that you made previously, and install the timing belt onto the camshaft pulley.
    2. Loosen the No. 1 idler pulley set bolt 1 / 2 turn.
    3. Turn the crankshaft pulley two complete revolutions TDC to TDC. ALWAYS turn the crankshaft CLOCKWISE. Check that the pulleys are still in alignment with the timing marks.
    4. Tighten the No. 1 idler pulley set bolt to 31 ft. lbs. (42 Nm).
    5. Make sure there is belt tension between the crankshaft and camshaft timing pulleys.
  8. Install the upper (No. 2) timing cover with a new gasket(s).
  9. Align the two clamps for the engine wiring harness with the cover mounting bolts.
  10. Install the spark plugs.
  11. Install the right mounting insulator with bracket. Tighten the bracket bolts to 38 ft. lbs. (52 Nm), insulator nuts to 38 ft. lbs. (52 Nm) and thru-bolt to 52 ft. lbs. (71 Nm).
  12. Install the No. 2 engine mount bracket and tighten to 38 ft. lbs. (52 Nm); install the control rod and tighten the bolts to 47 ft. lbs. (64 Nm).
  13. Lower the engine.
  14. Install the alternator and alternator bracket.
  15. Install the drive belt and adjust the tension.
  16. Install the cruise control actuator with bracket.
  17. Install the fender apron seal and right engine under cover.
  18. Install the right front wheel.
Jul 24, 2011 | 1997 Toyota Celica
Which way do u turn the harmonic balancer bolt to remove it
gas engine :counter clock wise use penetrating oil let soak lefty loosey Diesel Engines
The 2.2L diesel engine utilizes an exposed crankshaft pulley and a hidden crankshaft timing pulley/damper. The following procedure may be used to remove the exposed crankshaft pulley.
  1. Disconnect the negative battery cable.
  2. Loosen and remove the accessory drive belts.
  3. Turn the crankshaft pulley to align the timing mark with the engine pointer. This should be done if any further procedures are being performed which might disturb valve timing.
  4. Remove the retaining bolts, then remove the crankshaft pulley.
To install:
  1. Align and install the crankshaft pulley.
  2. Install the retaining bolts, then tighten to 10-17 ft. lbs. (14-23 Nm).
  3. Install the accessory drive belts, then properly adjust their tension.
  4. Connect the negative battery cable.
Dec 12, 2010 | 1994 Isuzu Rodeo
How do you remove the power steering pump from a 2001 Chev Blazer with the 4.3 engine?
4.3L Engine
    NOTE
  3. Remove the drive belt from the pulley.
  4. Install a puller tool such as J-25034, or equivalent onto the power steering pump pulley. While holding the pilot bolt, turn the tool nut counterclockwise in order to press the drive pulley from the pump.
    NOTE
To install:
  1. Position the pump to the vehicle and secure using the front retaining bolts to 37 ft. lbs. (50 Nm).
  2. If equipped, install the rear brace and tighten the retainers to 31 ft. lbs. (41 Nm).
NOTE
  1. NOTE
  1. Be sure to secure any hoses which may get in the way or rub other components.
Oct 30, 2010 | 2001 Chevrolet Blazer
Installing a timing belt
Timing Belt and Sprockets REMOVAL & INSTALLATION Fig. 1: If you plan on reusing the timing belt, make sure you note the direction of the rotation before removal 91053p69.jpg Fig. 2: If the special tool is unavailable, a suitable length and width straight edge can be used to align the camshafts 91053p10.jpg Fig. 3: Camshaft alignment using the special service tool 91053g61.gif Fig. 4: Insert the crankshaft damper bolt to turn the crankshaft and . . . 91053p64.jpg Fig. 5: . . . align the camshafts and the . . . 91053g64.gif Fig. 6: . . . crankshaft before removing the old belt 91053p66.jpg Fig. 7: Loosen the timing belt tensioner pulley bolt, slide the tensioner back and . . . 91053p67.jpg Fig. 8: . . . tighten the bolt to the farthest right hand side as possible to hold the release the tensioner pulley so that the belt can be removed 91053p68.jpg Fig. 9: . . . remove the belt starting from around the camshaft pulleys 91053p01.jpg Fig. 10: Installation of the tensioner spring and retaining bolt 91053g62.gif For information on timing belt recommended replacement interval, refer to Section 1. CAUTION
The 2.0L engine is an interference motor. Extending the replacement interval could lead to the belt breaking and severe and costly engine damage. Care must be taken if rotating the crankshaft or camshafts with the belt off, if resistance is felt, do not force them to turn.
  2. Remove the timing belt covers as outlined in this Section.
  3. Remove the valve cover.
  4. Place Camshaft Alignment Timing Tool T94P-6256-CH or equivalent, into the slots of both camshafts at the rear of the cylinder head to lock the camshafts into position. NOTE: If the special tool is unavailable, a suitable length and width straight edge can be used to align the camshafts.
  5. Loosen the camshaft timing belt tensioner pulley retaining bolt and move the tensioner pulley to relieve the tension on the timing belt.
  6. Temporarily tighten the tensioner in this position. NOTE: If the timing belt is to be reused, mark the belt for the direction of rotation before removing to prevent premature wear or failure.
  7. Remove the timing belt.
  8. If required, remove the sprockets as follows:
    1. Hold the camshaft with an appropriate camshaft sprocket holding tool.
    2. Loosen and remove the camshaft sprocket retaining bolt.
    3. Remove the sprocket from the camshaft.
    4. Repeat the procedure for the 2nd camshaft sprocket.
    5. Remove the crankshaft sprocket.
  9. Slide the crankshaft sprocket onto the crankshaft aligning the key-way.
  10. Align the camshafts using the Camshaft Alignment Timing Tool T94P-6256-CH. NOTE: If the special tool is unavailable, a suitable length and width straight edge can be used to align the camshafts.
  11. Reinstall the sprockets onto the camshafts and loosely install the camshaft retaining bolts.
  12. Tighten the camshaft sprocket retaining bolts to 47–53 ft. lbs. (64–72 Nm) .
  13. Loosely install the crankshaft pulley to verify that the engine is at TDC. Realign the marks if they have moved.
  14. Verify that the camshafts are aligned. NOTE: It is recommended to purchase a tensioner spring and retaining bolt through the dealer parts to apply the proper tension for used or new belt installations. The spring is bolted to the tensioner assembly and becomes a part of the engine. Ignore this notice if the tensioner spring is already installed.
  15. Reinstall the retaining bolt (W700001-S309) into the hole provided in the cylinder block and place the tensioner spring (6L277) between the bolt and the camshaft timing belt tensioner pulley.
  16. Tighten the retainer bolt to 71–97 inch lbs. (8–11 Nm) .
  17. Remove the crankshaft pulley and install the timing belt onto the crankshaft sprocket, then onto the camshaft sprockets working in a counterclockwise direction.
  18. Tighten the camshaft sprocket retaining bolts to 47–53 ft. lbs. (64–72 Nm) .
  19. Be sure that the span of the camshaft timing belt between the crankshaft sprocket and the exhaust camshaft sprocket is not loose.
  20. Be sure that the camshaft timing belt is securely aligned on all sprockets.
  21. Reinstall the lower timing belt cover and tighten the retaining bolts to 53–71 inch lbs. (6–8 Nm) .
  22. Apply silicone sealer to the key-way of the crankshaft pulley and install. Tighten the retaining bolt to 81–89 ft. lbs. (110–120 Nm) .
  23. Inspect the timing mark on the crankshaft pulley to verify that the engine is still at TDC.
  24. Loosen the camshaft timing belt tensioner pulley retaining bolt and allow the tensioner spring attached to the pulley to draw the tensioner pulley against the camshaft timing belt.
  25. Remove the camshaft alignment timing tool from the camshafts at the rear of the engine.
  26. Turn the crankshaft two revolutions in a clockwise direction.
  27. Tighten the camshaft timing belt tensioner pulley retaining bolt to 26–30 ft. lbs. (35–40 Nm) .
  28. Recheck that the crankshaft timing mark is at TDC for the No. 1 piston, and that both camshafts are in alignment using the camshaft alignment timing tool. NOTE: A slight adjustment of the camshafts to allow the insertion of the camshaft alignment timing tool is permissible as long as the crankshaft stays at the TDC location.
  29. An appropriate camshaft sprocket holding tool can be used to move the camshaft sprocket (s) if a slight adjustment is required.
  30. If a camshaft is not properly aligned, perform the following procedure:
    1. Loosen the retaining bolt securing the sprocket to the camshaft while holding the camshaft sprocket from turning with the sprocket holding tool.
    2. Turn the camshaft until the camshaft alignment timing tool can be installed.
    3. Verify that the crankshaft timing mark is at TDC for the No. 1 cylinder.
    4. While holding the camshaft sprocket with the camshaft sprocket holding tool, tighten the retaining bolt to 47–53 ft. lbs. (64–72 Nm) .
    5. Remove the tool and rotate the crankshaft two revolutions (clockwise) .
    6. Verify that the camshafts are aligned and that the crankshaft is at TDC for the No. 1 cylinder.
  31. Install the valve cover.
  32. Install the timing belt covers.
Aug 17, 2010 | 2000 Mercury Mystique
Procedure in changing timing belt
Timing Belt and Sprockets REMOVAL & INSTALLATION 2S-ELC, 3S-FE and 5S-FE Engines
  9. Remove the nut retaining the oil pump pulley. To install:
  10. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  11. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  12. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly. NOTE: Remove any oil or water on the idler pulley and keep it clean.
  13. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  14. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys. NOTE: If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  15. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  16. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  17. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  18. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  19. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt. NOTE: On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  20. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  21. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  22. Install the timing belt and check the valve timing as follows:
    2. Loosen the No. 1 idler pulley set bolt 1⁄2 turn.
  23. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  24. Install the spark plugs.
  25. The remainder of installation is the reverse of removal. Tighten each component to specifications.
Aug 04, 2010 | 1996 Toyota Camry
How to change a water pump on a 1995 ford windstar
Fig. 1: Front cover and water pump bolt size and location-3.0L engine
  2. Drain and recycle the engine coolant.
  3. Loosen the four water pump pulley retaining bolts while the accessory drive belts are still tight.
  4. Rotate the automatic tensioner down and to the left.
  5. Remove the accessory drive belt.
  6. Remove the two nuts and bolt retaining the drive belt automatic tensioner to the engine, then remove the tensioner.
  7. Disconnect and remove the lower radiator and heater hose from the water pump.
  8. Remove the eleven water pump-to-engine retaining bolts, then lift the water pump and pulley up and out of the vehicle.
  9. Remove the water pump pulley retaining bolts, then remove the pulley from the water pump.
To install:
Be careful not to gouge the aluminum surfaces when scraping the old gasket material from the mating surfaces of the water pump and front cover.
  1. Clean the gasket surfaces on the water pump and front cover. Lightly oil all bolt and stud threads except those requiring special sealant.
  2. Position a new water pump housing gasket on the water pump sealing surface using gasket sealant to hold the gasket in place.
  3. With the water pump pulley and retaining bolts loosely installed on the water pump, align the water pump-to-engine front cover, then install the retaining bolts.
  4. Tighten the bolts to the following specifications:
    1. Bolt numbers 1-10: 15-22 ft. lbs. (20-30 Nm).
    2. Bolt numbers 11-15: 71-106 inch lbs (8-12 Nm).
  5. Hand-tighten the water pump pulley retaining bolts.
  6. Install the automatic belt tensioner assembly. Tighten the two retaining nuts and bolt to 35 ft. lbs. (47 Nm).
  7. Install the alternator and power steering belts. Final tighten the water pump pulley retaining bolts to 15-22 ft. lbs. (22-30 Nm).
  8. Position the hose clamps between the alignment marks on both ends of the hose, then slide the hose on the connection. Tighten the hose clamps to 20-30 inch lbs. (2.2-3.4 Nm).
  9. Fill and bleed the cooling system.
  10. Connect the negative battery cable.
  11. Start the engine and check for leaks.
Hope this help; good luck and remember rated this post.
May 15, 2010 | 1995 Ford Windstar
Now toremove power streeing pump
See Figures 2, 3 and 4
0900c15280250684.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Installing the pilot bolt
0900c15280250685.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Removing the power steering pump pulley
0900c15280250686.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 4: Installing the power steering pump pulley
To install:
Jul 05, 2009 | 1994 Chevrolet S-10 Blazer
Power steering
look thru the front hold of pS pulley
see bolt hole (missing bolt now)
replace this bolt and belt
then tension it.
then tighten this missing bolt.
done.
just like mine.
im doing a timing belt now.
this is an interference motor , you do too.
Apr 07, 2009 | 1993 Geo Tracker
Saws Logo
174 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
