Question about EliteGroup KN1 Extreme Motherboard
Will not post
I just upgraded my processor and ram on this particular motherboard. I've reset the CMOS and even put my old stuff back in, but my computer will boot, but not post....At all. Is there a troubleshooting guide for this motherboard?
  • quanah Oct 20, 2007
    Problem was solved. The issue was that in the process of upgrading my RAM my motherboard was somehow fried. I used the suggestion above and it determined that the CPU was fine, but the mobo was gone.
    Scholar:
  • 155 Answers
No.
Unplug and remove everything from your motherboard, memory, PCI card, Hard disk, CD, etc…
Only leave the processor, its fan and the power supply connectors. Power up and listen for some beep. If you don?t hear any beep there is an issue with the processor or the motherboard. If you hear any beep start installing the memory and try again adding one more component until you discover which one is causing the issue.
Posted on Oct 19, 2007
  • Massimo Ardito
    Massimo Ardito Oct 20, 2007
    If you want you can post the motherboard, processor and memory type and i can verify any incompatibility issue for you.
No display even if i upgraded my ram,and my video card.please help me
flash the CMOS and remove the battery and put it back again.. put the CMOS jumper in 2-3 settings.. after 5sec put it back again in 1-2 settings.
Jul 04, 2011 | Dell (E210882) Motherboard
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
When i replace and upgrade my ecs p4vmm2 ram up to 1gb..first it enter os but when i restarting im stuck with checking nvram"..im done with re installing the usb wire,reseting cmos..unplugging...
i think u are trying to upgrade ur ram with ur existing ram, if this then plz check ur old ram frequency and then select another ram with same frequency, means u have to install rams with same frequency. i hope u can understand what m i saying.
Nov 07, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
No boot after putting 2 Gb additional in Mb
try to reset cmos after putting 2 -1 gb rams(pulout power cord,and change clear cmos jumper to clear for 10 secs,or just remove motherboard battery for 30 secs,post mb info if no luck with cmos clear
Jun 12, 2009 | Acer Aspire™ T180 PC Desktop
Bootup - NOT - Soyo Slot 1 SY-6VBA133
Put everything back as it was before, clear the CMOS, if it's still a blank screen, end of life for the MB.
Mar 30, 2009 | Computers & Internet
Just installed new CPU on M848A v2.1 and pc will not POST
becose the processor not support that.replace it by a suitable one.
Jan 16, 2009 | PC Chips M848ALU Motherboard
Upgraded computer and won't come on, no bios.
disconnect all and reconnct it.something jammed .may be *********** bord circuit is ground.
disconnect hdd ram then try.
to reattch one by one.
try with only smps ,mother bord and ram.
also check processor sitted correctly.
Nov 24, 2008 | MSI MS-6734-10 (-6734-010) Motherboard
Processor Upgrade and Memory query
This motherboard supports up to 3gig of RAM so you can go ahead and upgrade it, There's no particular order fo install the RAm just put it to the empty slot then that's ok..
Hope that helps.........
Aug 21, 2008 | Intel D845HV (735858149143) Motherboard
Processor upgrade problem
If you are completely sure the FSB is right, I mean that the motherboard supports the CPU, and that there is no jumpers out of place... just reset the BIOS (take the motherboard lithium battery off and let the PC completely without power and any other cable connected) take the RAM out and all devices too. Arround 10 minutes later put just the CPU and the lithium battery in their places and boot up the system.
Last try is to disassemble all and just try with motherboard on a table with only RAM and Video. If you do this BE CAREFUL not to place the motherboard over any metallic thing, just a piece of wood is better than anything.
If this does not work, take the CPU to Guarantee...
Mar 10, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
PC Won't Start After Initial Post
make sure the ram is the same name of kind. if you can get the old computer on, hit the esc key and go in the bois and hit save, and restart. this should bring the computer back up. check the piggs (jumpers) on the motherboard to see if all are the same, more them around and try each one, I hope this will help you.
Dec 16, 2007 | MSI K8N Neo2-F Motherboard
EliteGroup KN1 Extreme Motherboard Logo
83 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
