Question about Amana Front Load Washing Machine Washer Soap Dispenser Nfw7200tw
Washer will not advane from wash to rinse
Our washer will not advance from the wash cycle to the rinse cycle. Here is what I have done to this point: Removed the pump and hoses to check for blockages. There are not any. When the washer stopped between the wash and rinse cycle I removed the electrical connection from the pump and plugged it into the wall, the pump emptied the tub and the washer advanced to the rinse cycle. Any thoughts on what would cause this. I am an electrician but I cannot find an electrical schematic anywhere on the washer.
  • Amana Master
  • 1,479 Answers
It sounds like, when the dial gets to the pump stage, the contact expected to pump the water out isn't making contact. That could be a burnt contact within the controller, or a loose wire to to the pump from that section of the controller. Once the weight, or water level was low enough from your pumping it out, the sensor that checks the level/pressure allowed the spin. The problem could be on the control board too.
Here's an incomplete schematic I found:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/474475-front-load-washer-amana-model-nfw7200tw.html
Posted on Jan 05, 2014
catriver
  • 878 Answers
SOURCE: Amana washer "goo" on clothes?
Ann, these Amana's are the mother of all washers to change out the seal and bearings. It's possible you just have a lot of gunk built up on the inside of the basket from years of washing. I would not put a cent into it. You are better off getting a new direct drive washer. Catriver...post back.
Posted on Oct 08, 2006
catriver
  • 878 Answers
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Posted on Feb 21, 2007
fanny
  • 146 Answers
SOURCE: Amana Top Load Washer model# LW3502W
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Posted on Oct 31, 2007
SOURCE: Amana washer belt replacement
Steps for Replacing the Belt
Tools needed:
Nut driver or socket set.
Torex screw driver.
1. Unplug the power cord from the
electric socket and remove the
front panel.
2. Disconnect the power coupling
from the motor.
3. Disconnect the 2 hoses from the
pump. Be aware that the pump
still contains between 1 and
2 cups of water, and it WILL
all come out.
4. Remove the belt from the idler
arm, pushing the belt UNDER the
idler arm. Yes, your hands will
now be quite greasy.
5. Remove the belt from the main
transmission by pushing the belt
under the transmission pulley.
6. Remove the 4 bolts that hold the
motor assembly to the washing
machine body. Remove the motor
assembly with belt from the
washing machine.
7. Turn the motor upside-down. With
the torex screwdriver, remove the
3 bolts that hold the pump to the
motor. Remove the pump from the
motor (in my case, the motor shaft
fit into a slot in the pump; while
it was snug, it was not melted or
rusted, and did just come out).
8. Clean pump and motor as desired.
9. Install new belt and reverse the
steps to re-install.
Posted on Nov 12, 2007
SOURCE: Amana LWA50AW Washer Leaks!
Same problem here. It's coming from Shaft. Any instructions???
Posted on Apr 26, 2008
Tip
We have a Kenmore 90 series hvy duty top loader, it works fine in wash cycle but...
This advice is for all Whirlpool manufactured TOP LOADING washing machines. This includes Kenmore, Estate and Roper models as well. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the white plastic lid switch connector plug. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located adjacent to one of the lid hinges in the rear.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first (this is the end of the clip with the 90 degree bend), and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
I hope this information is helpful..
on Jul 26, 2010 | Washing Machines
My Kenmore washer won't advance through it's wash cycle
I just had the same problem and had to have it repaired. It was the "lid switch."
Jun 05, 2010 | Kenmore 24032\24036 Top Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
Stops during rinse cycle
Dear customer,
              We recommend the following when a washer's cycles dont advance..
  1. If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  2. If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  3. If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
For details on how to self test these parts plz refer to http://www.acmehowto.com/howto/appliance/washer/washer.php
Plz rate this solution.. thank you..
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Kenmore heavy duty series washer
    you need a new timer. order part thru sears.
    Mar 19, 2008 | Kenmore 24032\24036 Top Load Washer
    Amana Front Load Washing Machine Washer Soap Dispenser Nfw7200tw Logo
    166 people viewed this question
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
