Question about Hamilton Beach Professional Nonstick 14960 Iron
Iorn Does not heat up
    Sergeant:
  • 236 Answers
If it's completely dead (no lights or anything) then check the fuse in the plug by placing a new one in (same rating, probably 13 amp) and testing. If it's not that then suspect either the heat control (thermostat) or the element. These aren't your basic DIY things to mess with unless you know what you are doing.
Posted on Jan 05, 2014
My iron turns on and lights up but no heat how do i do a re start on it
first of all check the iron heat increasing switch and if it is working good..probably heat coil gone,,replace heat coil .
May 02, 2016 | Irons
How to fix the iron that leaks
Sorry , It would cost more to repair , than replace with a NEW IORN.
Check it out .!
Mar 12, 2015 | Irons
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
No problems just need manual for Oreck cordless speed iorn manual
You can download the manual at
http://www.oreck.com/PUG/IRONMANUAL-JP8100.pdf
Jan 16, 2010 | Oreck Cordless Speed JP8100CA Iron
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 | Irons
Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Dec 30, 2008 | Rowenta DX-8800 Iron
Problem with steam iorn
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jun 04, 2008 | Irons
Teful ultraglide easycord fv4260
Hi.
If you move the cord up/down/side to side and the iron works then you have a problem with the cord-damaged/broken or the pins(bent) and the wall power outlet pins(gone wide) are not making a GOOD connection.BE CAREFUL YOU WOULD/COULD TRIP THE FUSE AND ALSO DAMAGE THE POWER OUTLET-BURN/ARC AND CAUSE SOME DAMAGE.check the pins and connection.This will be a step by step checking of the cord and connection pionts.
Hope this helps
Jay
Nov 13, 2007 | Tefal UltraGlide Easycord FV4256 Iron
Hamilton Beach Professional Nonstick 14960 Iron Logo
35 people viewed this question
Top Hamilton Beach Irons Experts
Jim Thurston
Andrew Taylor
Andrew Taylor
richie46
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
