Question about Discovery Kids Daisy Projection Alarm Clock
Turn alarm off or 309t - Discovery Kids Daisy Projection Alarm Clock
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Kleenmaid rangehood
I found the manual for the Timex T 309T here:
http://www.manualowl.com/m/Timex/T309TT/Manual/272204
Oct 27, 2013 | Timex T309TT Clock Radio
How do I keep the alarm from flashing? I just want to turn off both alarms. Timex nature sounds with cd T621T, Thank you
Hello, To turn off the alarms follow these steps -
  1. After the alarm sounds, press the "F" alarm off/reset button to shut the alarm off but retain the 7-5-2 alarm settings.
  2. If you want to turn the alarms completely off and cancel the 7-5-2 settings, press the "alarm" button so that the "alarm" indicator is no longer visible. As long as you can see the word "alarm" on the display the alarms will continue to go off according to your 7-5-2 alarm settings.
Regards, Tony
Mar 24, 2011 | Timex Nature Sounds LED Clock Radio
Where can I get a manual on how to operate timex clock T-309T.
I could not find T-309T but I found the users manual for T-308T. Maybe this manual will help. The manual can be downloaded at: http://portablemedia.manualsonline.com/manuals/mfg/timex/t308.html.
I hope it helps.
Nov 11, 2010 | Timex Auto-set Clock Radio
Alarm stopped working
sounds like the system is in valet mode.
locate a switch under dash if a toggle switch is found then turn on key and flip switch. turn key off if led is off try alarm.
If a push button switch is found then turn ignition on and press the switch for 10 seconds, then turn key off iff led is off try alarm.
Sep 22, 2009 | Vehicle Parts & Accessories
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
Can't turn off alarm
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch.
Press MODE again to change alarm time.
Press MODE again to change time.
Press RESET once to display current alarm time.
Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
May 05, 2009 | Watches
Directions
Hi - You can download the manual by clicking the link underlined in blue below:
T-309T
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | Timex Auto-Set Dual Alarm Digital Clock...
Unwanted alarm
using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
Setting the alarm???
Here's a website for the manual for the Timex T309 model. As suggested elsewhere on the web, I found this by googling Timex T309 without the t at the end. This looks to be the same model.
http://www.timexaudio.com/pdf/T309_IB57517_39.pdf
Sep 27, 2007 | Timex T309TT Clock Radio
Discovery Kids Daisy Projection Alarm Clock Logo
18 people viewed this question
Top Discovery Kids Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Discovery Kids Audio Player and Recorder Expert? Answer questions, earn points and help others
