Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
My Transcend Hard bDrive refuses to go on and makes a funny noise, please help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 196 Answers
This sounds like physical head or disk damage. Take it to a recovery expert. Not fixable by software.
Posted on Jan 18, 2014
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: my transcend external hard disc is not detecting in my computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Jul 31, 2012
Hard bdrive not in working
If you could have been more specific about the issue...http://www.makeuseof.com/tag/external-drive-not-recognized-this-is-how-to-fix-it-in-windows/
Read the above link to reslve hard drive if its not recognized.
However there can be lot of other reason for hard drive not working.. was it damaged or it regular wear and tear took it dow. in such case we consider that the hard disk has failed..
you can refer to https://goo.gl/NRdQZl for further help.
Dec 26, 2015 | Hard Computers & Internet
I dropped my transcend storejet d2 now it refuses to read yet the computer can recognise it has been connected
The reason behind your drive is being not recognized by your is computer is that your drive has experienced physical damage due to mechanical stress. And now the important thing is that don't tamper much with your drive and if the data stored in the drive is very important then consult a data recovery specialist. You can visit this link for more more information
http://stellardatarecoveryservices.blogspot.in/2011/11/physical-hard-disk-failure-symptoms-and.html
Apr 09, 2013 | Transcend Computers & Internet
The drive is making a funny clicking noise. Imac doesn't see the drive.
The funny clicking noise you are hearing is usually from a mechanical failure within the hard drive. The drive will need to be replaced at this point. If the drive is still under warranty you will want to process an RMA.
http://www.lacie.com/us/support/
Robert from Blitware
Jun 17, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
No response freez making funny noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Is it an external drive?
If it is, open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Lastly, if its not an external drive, the same applies because, its still all about hard drive.
I wish you all the best.
Jan 08, 2010 | LaCie F.A. Porsche (301177) Hard Drive
Storejet 2.5 makes noise and does not recognize one partition
Delete the partition is being unrecognized by the system and then create a new partition and format it. About the noise your drive, try to relax your drive, try not to use it for a several hours and then plug it back. Format your entire drive but be sure that you back-up all the contents of it.
Nov 08, 2009 | Transcend STOREJET 2.5 HI- SPEED USB...
Break make funny noise at slow stop
CHECK FOR RUST BUILD UP ON FRT WHEEL SPEED SENSOR CLEAN RUST ROAD TEST / IF NOT SOLVED MAY NEED TO REPLACE HUB BEARING
Jan 23, 2009 | 1999 GMC Sierra
Hard drive is not working
Try the cables. Push them in as far as you possibly can.
Jul 30, 2008 | Apple Power Mac G5 Desktop
Printer making funny noise and print is almost peeling off the page on the right side
Your problem is with the fixing film in the fuser assembly (HP Part #RM1-3044). The brown material you see is the plastic film ripping and peeling off of the hheating element.
Jan 23, 2007 | HP LaserJet 3050 All-In-One Printer
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
64 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
