Question about HEWLETT-PACKARD Hewlett Packard OEM HP Q3984A 110 Volt Fuser Kit Fuser Unit (gq3984a) for Color LaserJet 5550 5550dn 5550dtn 5550hdn 5550n
Card stock jam
Paper jam
  • HEWLETT-PACKARD Master
  • 783 Answers
Hi, up to 75 lb. (281 gsm) only.
If Still Having Problem Then Follow Us On :Brother Printer Support
Posted on Jan 17, 2014
Getting paper jam message but there is no paper jammed will not reset itself
Generally, when a paper jam message is displayed, there is in fact some sort of debris, dirt, or paper pieces blocking the paper jam sensor. My suggestion, take a thick piece of card stock and manually feed it through the paper path; this should hopefully clear any debris that is blocking the jam sensor in that area. Also, try spraying some canned air into the paper path, as if there is dust blocking the sensor, it will be more likely to be removed with air than card stock.
-David.
Nov 03, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Paper jams with thicker stock paper
Your pickup tires on the printer may be worn, how many prints have you made on this printer. it may be time for a maint. kit.
May 31, 2009 | Brother MFC 210C All-In-One InkJet Printer
Jammed card stock
This machine has auto paper type sensor- may be at fault
May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
Paper jam
I have had this problem with other printers. What I did is to take a sheet of Card Stock 8.5" x 11" , putting it in the Feed and push the print button while applying a small amount of pressure on the card stock. Sometimes a small piece of paper gets in the path way and indicates a paper jam. Could be another problem that is causing the jam indication. Worth a try. Bud
Jan 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
PIXMA MP450 alarm light is on and it says paper is jammed but there isnt any jammed, please help?
You could try this, but there is no guarantee. There are a lot of sensor in the paper path of a Canon printer. When these sensors get stuck in the up position, pushed up when paper is present, you get the paper jam alarm when no paper jam is present.
The trick to try that sometimes works is to run some index card stock through. Insert the index card stock in the paper tray, run a print test and as it runs put some gentle firm pressure on the card stock to ensure it travels smoothly. Once it is done the sensor may have reset itself. In lieu of card stock you can use a thick magazine cover and cut it to size of an 81/2 x 11 piece of paper.
If this works great. If it doesn't let me know and please don' t bother to rate this if it fails. It works some of the time and not most of the time.
Thanks,
Worldvet
Nov 20, 2008 | Canon Office Equipment & Supplies
Wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
T642 Paper Jam and Check paper stock jamming.
You need to change the paper type when using card stock, plain etc.
As for the paper jams; you need to check the exit sensor at the exit door, also if you have a duplex, 2-3 drawer you also need to check for jams.
Sep 08, 2008 | Lexmark T642 Laser Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
HEWLETT-PACKARD Hewlett Packard OEM HP Q3984A 110 Volt Fuser Kit Fuser Unit (gq3984a) for Color LaserJet 5550 5550dn 5550dtn 5550hdn 5550n Logo
56 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
