Question about Garden
Farm tractor revving up and down then will shutdown
Tractor will shut down as if it has run out of fuel. Upon restart it requires constant turning over, sometimes a shot of ether to boost the start cycle.
    Sergeant:
  • 458 Answers
The tractor I have operated had a sediment bowl/ water trap.Try cleaning that out.
Posted on Jan 02, 2014
Onan 4000 Microquiet shuts down after running for 20-30 minutes. If I direct 2 high power (400+ CFM) fans to the underside of it -it will keep running indefinitely.
check the current draw from the machine
being a 4000 watt machine if you are drawing 4000 watts it is overloaded as that is the surge power available not constant power which is around 3500 watts
that would account for the requirement of fans to keep it cool
even if It is not 4000 watt what ever capacity it is it is running in an overload situation
Jul 10, 2016 | Onan Microquiet 3600 & 4000 Generator
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
Revving problem
could also be the shut off valve. stops engine if it is dropped or on its upside down. or could just be the fuel filter...
Jan 02, 2014 | Garden
How to fix restart the pc when you turn it off?
Check to make sure that you are shutting down and not restarting when you go to
start>shutdown
also make sure the button isn't lodged in or already pressed upon shutdown
if you have a different version other than windows 7 let me know
Aug 27, 2012 | Dell Computers & Internet
Motor starts and runs good till it warms up then as it warms up shuts down and wont restart till it cools back down
2 things to check are the ignition spark immediately after this shutdown, which would indicate a faulty coil, and loosen the gas cap to see if a vacuum is being pulled on the tank due to a faulty vent, which would prevent fuel from entering the carburetor, but chances are, on a riding mower this is either a faulty ignition coil or a fuel system issue. The best way to tell if it is a fuel system issue is to apply the choke as it begins to die and if it is running out of fuel it will pick back up for a little longer. If no change when the choke is applied then check the spark at the plug(s).
Jun 28, 2010 | Garden
The computer hiberates when I close the lid, then I have to shutdown & restart to resume working. Can I avoid this somehow?
  1. right click your desktop and select properties
  2. select the screen saver tab
  3. at the bottom click the "power" option
  4. deselect the option for hibernation
  5. make sure your hdd is NOT set to turn off when the lid is closed
you can actually set the laptop up to continue running even programs when the lid is closed. this is the best option if you are constantly running application that require an extended wait period between startup and shut-down
good luck and pls rate this post
Mar 23, 2010 | Toshiba Satellite Pro L300 Notebook
Starts, runs a few seconds then shuts down. Will restart immediately, but then shuts down again. 32.5 KW, White diesel eng.
Check for a low lube oil sensor problem first. Could be low oil pressure or a failed sensor. The sensor is timed and if pressure doesn't come up, then unit is shutdown.
Check fuel filter and also air leaks in the fuel supply lines.
Check if the fuel shutoff solenoid is responsible for the shutdown. If it closes just before the engine quits, then it is being commanded to shutdown, probably as a safety interlock.
Oct 11, 2009 | Kohler Electrical Supplies
Lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
