Question about Dryers
I have a 3 week old Kenmore Elite steam dryer model #796.8107, 796.9107. It appears the dryer has "locked up" The "check filter" indicator is flashing and "CL" is flashing on the display panel. I clean out the lint trap after each use. I've vacummed out the vent duct of the lint trap. I've unplugged and let the dryer sit for 15 seconds in hopes that it would reboot the system. The dryer vent is a direct feed into the wall. I've followed the task list for troubleshooting in the manual for possible problems and still the indictor lights are flashing. HELP?
4 Suggested Answers
SOURCE: Kenmore Elite Oasis Dryer with Airflow problem
same problem removed back cover cleaned lint found pulley had unscrewed and belt was off.installed pulley rev threded and put belt back on.
Posted on Apr 07, 2008
ttdesignbilt
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
Posted on Jan 24, 2009
  • 183 Answers
SOURCE: I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. The lig
when you removed the screen from the inside you disconnected the wires from the 2 metal strips. now you need to remove the lower panel on the front. and reconnect them. you will need a T-20 torx and unplug the dryer to be safe. the wire will have 90 degree push on connectors and it does not have any polarity concerns. the two male connectors are real close to the top of the panel, maybe even slightly under the other panel. By the upper right of the silver fan duct.
Posted on Jan 03, 2012
What does LOC error code mean?
I believe that the front panel lock has been enabled. (This keeps children from starting the unit accidentally.) Without the model number of your dryer, I can't be absolutely sure of the key or keys that you need to press and/or hold to toggle the lock off. On some Elite Steam Dryers, including the Kenmore 417.81100000, you need to press and hold the "Add Steam" button for 5 seconds. You'll hear a chime as the feature is disabled. On the Frigidaire Affinity dryers, the Select and Options button need to be pressed together to toggle the lock on and off.
Look on the control panel for a fine print "Child Lock" label or a padlock symbol below a specific key or with a line between two keys. That will indicate the buttons that you need to try. Otherwise check the manual.
If you have attempted to clear the lock and there was no response, the key pad may not be communicating with the brain of the appliance. This is usually a keypad fault and is cured by replacing it. However, it can indicate a wiring problem or a problem with the control unit.
If you don't have any indication of the child lock buttons or they didn't work, please add a comment with the model number. If the dryer is not currently running, you can look in the unit and try to find the model number. (It should be on the inside of the door surround for most dryers.) A few companies put the model number in other spots. If you know the manufacturer that will help me assist you further.
I hope this helps.
Mar 11, 2016 | Dryers
What does loc mean on kenmore elite dryer
It indicates that the control panel settings are locked.Which is a safety feature. Press the SELECT and OPTION button or press & hold the "Add steam" button for 6 seconds to reset it.
Sep 13, 2014 | Dryers
2013 Kenmore elite model 796.8107#, 796.9107# steam dryer
First, the 796 model means that the dryer was made by LG. The CL code usually means that the Control Lock (Child lock) is engaged. There are two buttons that you should press and hold for ~3 seconds to disengage the lock. There will be be a small icon (padlock or child's face and the padlock) with lines to the appropriate buttons. If only one button is used that icon will be on the single button. (Frequently it will be the Temp and Option buttons or just the Dry Level button. On some models, it's the Anti-bacterial or Rack Dry button.)
As for the lint trap issue, check the rest of your vent system. Sometimes, the cover on the outside of the vent comes loose and blocks the vent.
I hope this helps.
Jan 02, 2014 | managemylife.com
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
The Kenmore Elite Oasis Steam Dryer - almost new - worked well last week. This week no power to dryer; 220volts is present to dryer. Any ideas?
You might want to take a look at the vent pipe for lint. If the exhaust thernistor detects high temps it shuts down the dryer. Bravos service manual (same as oasis)
Apr 29, 2011 | Kenmore 67082 Electric Dryer
I have the Kenmore Elite Gas Dryer (not steam). I
Take pantyhose around the inside and see if it catches.
Pay particular attention around the drum/door area.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 11, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
