Question about Panasonic Lumix DMC FT4 / FT4 Digital Camera
My camera won't turned on . after several times charging my battery. it still turned off sometimes, it can be turned on , after taking 3-4 pictures (battery indicator show "full charged") , its suddenly turned off and cannot be turned on again . until now please help contact me dhoviar@gmail.com
    Problem Solver:
  • 12 Answers
That means your batteries are died. You have to buy new batteries. Has happened to me before too.
Posted on Jan 02, 2014
Valiis
  • 72 Answers
SOURCE: Charging Problem
Sounds like the circuitry that controls the charging of the battery has gotten damaged. You can try using regular non-rechargeable batteries if the camera can use them. Otherwise you will have to find another way to charge the batterys, if you can find an external charger for the batteries that should work too. Hope this helps.
Posted on Aug 26, 2007
jackboy
  • 2985 Answers
SOURCE: Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Posted on Aug 29, 2007
  • 11967 Answers
SOURCE: My camera stops working but the battery showed full.
Those are the symptoms of a battery that has been charged many times or has been allowed to completely discharge once or twice. Try some new ones.
Posted on Jan 06, 2010
  • 186 Answers
SOURCE: Panasonic DMC-FX33 has operated perfectly for 3 +
Hello. If you suspect this is a lens problem ,I agree. I've had good results tapping the camera into the palm of my hand while its trying to open. Also try conecting your transfer cable to the camera and then press the power button, this keeps the viewing screen turned off sending full power to the lens mechanism. Lastly,and I should have mentioned it first,If you have a piece of exposed photo film,cut a small strip and work it in the gaps between the lens barrels to try to remove anything which may be stuck in there
builderdale
Posted on Jan 13, 2010
jgroves705
  • 536 Answers
SOURCE: My camera, even with fully charged battery, the
edkhim:
It sounds like your battery has reached the end of its usable life. You have done very well to get several years worth of use out of the original battery, but it's time to buy a replacement battery and recycle the old one.
From page 9 of the user manual for this camera (click here for user manual), this camera uses a model DMW-BCE10PP lithium ion rechargeable battery.
Luckily, this model of battery is currently on-sale at Amazon.com for $19.77 as of 2:45AM Feb 17, 2011! (click here for link)
Disclaimer: Please note that I have done my best to try to provide the correct information about the type of battery that you need and with the troubleshooting of your issue; however, there is still a chance that that I have not correctly diagnosed the issue and that the battery I suggested above may fix the issue or even may not work with your camera. Please double-check my diagnosis before purchasing anything!
Thank you for using FixYa
Posted on Feb 17, 2011
My digital camera is Samsung Galaxy, Model no is EK-GC100 and it won't turn on.
When the camera is becoming warm while charging the battery, the battery must be charged. So no need to check for dirty contacts. If you have a multimeter perhaps you can measure the voltage on the battery. While just measuring the voltage, the battery must give a little more then printed on the battery. So when on the battery is printed 3,7 V toy should measure 3.8 or 3.9.
Anything less means the battery is not good.
Now the causes of not switching on. Sometimes the on / off switch is defect. Sometimes the (mini) USB connector is defect and telling the camera, there is still a plug in the camera. It won't switch on. Sometimes the display button must be pushed several times, so the display shows something. And sometimes, the camera is defect.
Carefull investigate the connector and on / off switch, but be aware cameras sometimes become defect, without telling you what is wrong.
I wish you luck.
Nov 10, 2014 | Cameras
Won turn fully charged battery
How long you have the battery? I suggest you to fully discharged the battery and then charge it as much as you can, do this circle for several times. Hope this can help
Jul 23, 2013 | Fuji FinePix A330 Digital Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Built in battery wont hold its charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 21, 2012 | Cameras
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
My camera wil not power on.
Depending on the situation, it could be several issues.
- Battery may not be charged, or wasn't charged properly. - Battery is cold. - Camera may actually still be on, but it won't show on the monitor because you may have them turned off.
Try this: Press DISP until shooting data or photo information displays, it should show up at some point. If it doesn't then it has to be the battery.
If you don't think it is, try and provide extra information on when was the last time you used it or the last time you charged the battery and etc. Thanks!
Aug 23, 2011 | Nikon COOLPIX P80 Digital Camera
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
Exilim z600 Static on viewing screen. Sometimes won't turn on/off
More than likely, you've just got a bad camera. I've helped with several problems with P/S cameras where the screens are either noisey or records a static like image. 9 times out of 10, it's the processor. Unless the camera is new or still under extended warranty..,
Feb 04, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Panasonic Lumix DMC FT4 / FT4 Digital Camera Logo
73 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
