Question about Acer Aspire 3000 Notebook
Exiting broadcom pxe rom - Acer Aspire 3000 Notebook
SOURCE: Broadcom UNDI PXE-2.1 v10.0.9
The Broadcom PXE looks for a boot device/files from a network source if the network cable is't plugged in then you get the PXE-E61: Media test failure check cable, you can turn this off in the bios, when this doesn't find any boot information it moves onto the next boot device which is defined in the bios, usally the dvd drive then the HD. If this is a Altos server you have bought they are not supplied with an OS so it wont boot from the HD to begin with, if you already had a OS installed and it wont boot then there is something wrong with with the HD or the connectors or posibly the boot sectors are corrupted, if the device is making th tak tak noise the it is having trouble reading te device.
Posted on Aug 12, 2008
freetek
  • 5568 Answers
SOURCE: Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Posted on Mar 21, 2009
frankzjm
  • 191 Answers
SOURCE: My acer 5620Z laptop cannot find its operating system
you can do check HD follow me:
1) open the cover at back of laptop
dc0d736.jpg 2) take out HD body see picture
5d35e3d.jpg 3) put it back in same way, then power on if bios find HD, the error message should be gone.
4) if still show error, you need change other HD, till the bios find out HD drive.
here you can download the service manaul to reference.
hope you fix it well, any question ask me any time please
Posted on May 14, 2009
  • 13433 Answers
SOURCE: my acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Posted on Jun 07, 2009
corahudo
  • 3 Answers
SOURCE: No bootable device
Do you have the original cds for the computer? If you do, you will hae to download everything beginning with windows whatever you have. Unfortunately eveerything saved on your hard drive will be erased, but your computer should work after completing this.
Posted on Jun 28, 2009
First ther was a error message, then the pc make nothing.
If you have a spike in the power, unplug, remove the battery, then hold the power button down for 1min or 60s, to release any built up shock power. then insert the battery, (no power cord) push and hold power button for 1 -2 - 3 s. release and see what happens.. now what OS is installed on the HDD. and check the BIOS to see how the boot sequence is set... seems your error show you set to boot to NetWork not HDD
May 28, 2014 | Acer Aspire 5500 5570-2609 Laptop
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Dell Computers & Internet
Broadcom UNDI PXE-2.1 v12.20 copyright(c) 200 - 2009 broadcom corporation copyright(c) 1997- 2000 intel corporation all rights reserved client MAC ADDR: 88 AE 1D 6F 5A 3A GUID: 478ADE06 B852 67B5 10E7...
From the description it is the hard drive, remove hardware and reseat back into position, sometimes this will restart the hard drive, if no change chances are you will need it replaced, but I would suggest getting it tested first.
May 26, 2012 | Acer Aspire Computers & Internet
Prablon may loptop pxe-mof exiting broadcom pxe rom .broadcom undi pxe-2.1 v14.0.8
I think you hard drives failed. When the hard drive fails, the boot tries to find another way to boot up, so if the boot sequence lan is enabled, it will try to boot from the lan port (in your case broadcom pxe), when it can't boot from here either, it exits (exiting broadcom pxe). Replace your hard drive and re-install windows.
Oct 14, 2010 | Computers & Internet
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 31, 2010 | Lenovo 3000 G530 Notebook
My computer which got on friday is not working, when i start my computer it goes to a black screen. And than this message comes up: Broadcom UNDI PXE - 2.1 v11.4.1 Copyright (C) 2000-2008 Broadcom...
What is your computer brand?
Just turn it on and keep pressing esc or delete or F2 key (depending on the model. But yuo can try any of them. This will take you into the bios screen. In the bios check if hdd is detected. If not - replace HDD>if yes > reset bios to defaults and start recovery (using supplied RDVDs or Recovery partition.
You will find exact instructions in user manual.t
thanx
Sep 14, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3000 Notebook Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
