Question about Brother MFC 7420 All-In-One Laser Printer
BROTHER MFC-8710DW CONNECTION TO NETWORK ERROR
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
  • 7 Answers
SOURCE: NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Posted on Aug 27, 2009
  • 62 Answers
SOURCE: how do I network brother mfc-440cn printer - what
  1. Plug the printer into a computer on your network.
  2. This computer must be on and remain on for the printer to work.
  3. Add this local printer to this computer in "Control Panel" - "Printers".
  4. Now share the printer.
  5. Go to another computer on your network.
  6. Add this printer (as a network printer) to this computer in "Control Panel" - "Printers".
  7. The system should find the printer and add it...
Posted on Nov 15, 2009
  • 3 Answers
SOURCE: Brother MFC-790CW Printer is not receiving any
this printer uses a 3rd party program to print over the network. try reinstalling the CD software. This will fix it. The problem is that the printer gets lost on the newtork if the router reassisgns it a new IP, other than 192.168.1.66 that it expects. Routers may do this upon resetting. You can reserve the ip address in the router settings, and make it static in the printer, but that is more work. If you can USB print to the printer, this is all that is wrong.
Posted on Jan 19, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
How can I download control center 4
one might think at brothers.com support /downloads
Mar 15, 2015 | Brother MFC-8710DW
How to eleminate the line on the edge of the paper
There are many types of lines. Each one requires different approach to solve. Please be very specific and describe it
Oct 14, 2014 | Brother MFC 8710DW
How do you install power supply?
Go To Below official Brother Printer Page For Your problem, http://www.printertechs.com/other-instructions/replacing-the-swing-plate-assembly-long-method/325-step-3-removing-the-power-supply
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Jun 10, 2014 | Brother MFC Series MFC-8710dw MFC /...
How do i reset the usage counters for fuser, laser and pf kit 1?
Hi Ron, to reset counters all you have to do is press the 3 and 9 buttons simultaniously when unit is in the ready state. Then scroll down to the unit you wish to reset and follow directions on the screen. After resetting, turn machine off/on. Very easy to do.
Apr 29, 2014 | Brother MFC-8710DW Multifunction Laser...
Brother mfc 8710dw
Please mention the exact problem
Nov 19, 2013 | Brother MFC Office Equipment & Supplies
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
How to connect brother MFC-5440CN to Bt voyager 2091
Connect machine to lan. Run the network drivers. PC should find the mfc.
In case you have to do some settings have a look into the network manual which is a pdf document on installcd.
When questions left go to brother homepage of your country and search your mfc and then the faq for networking answers.
Dec 30, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 7420 All-In-One Laser Printer Logo
32 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
