Question about Dishwashers
Oko favorit 50750 v1
Detergent dispenser is not opening on cleaning cycle
COXY
  • 76 Answers
SOURCE: Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Posted on Nov 18, 2007
SOURCE: Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Posted on Mar 31, 2009
Todd_pdx
  • 22 Answers
SOURCE: detergent stays in the dispenser
Clean and dry your dispenser prior to filling with detergent.
Use only fresh detergent.
Do not place anything ie. cookie sheets, cutting boards in the path of the water obstructing the dispenser.
Do not allow anything to fall between the racks and stop the spray arms from turning.
Always turn the hot water on at the sink prior to starting you dishwasher they use less than 2 gallonsof water in the initial cycle and they require 120 deg f water. Unless you have hot water recirculation in your home.
If you have low water volume or low water pressure due to bad impellor or windings in circulation pump. The water volume or pressure will be insuficient to reach the dispenser.
poisnscorp
  • 111 Answers
SOURCE: Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Posted on Nov 14, 2009
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Detergent dispenser door will not open during the cleaning cycle. Dishes are not being cleaned.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 24, 2010 | Frigidaire 24 in. FDB636GF Built-in...
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
Our shu66c05uc Bosch dishwasher does not dispense the detergent.
Most likely the solenoid that operates the lever on the detergent door is faulty. Only solution is to replace the whole dispenser, unfortunately. It is possible that the controller is not activating the dispenser but less likely.
Jul 21, 2009 | Dishwashers
Detergent dispenser does not open in wash cycle
mght have a lot of dried up sop in it preventing it from opening.clean the dispenser out real good.please leave feedback
Apr 29, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Detergent Dispenser does not open
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwashers Logo
11 people viewed this question
Top Dishwashers Experts
Owen Barnes
