Question about managemylife.com
2013 Kenmore elite model 796.8107#, 796.9107# steam dryer
It seems that my dryer has "locked up" Help! It is 3 weeks old! The "check filter" indicator is flashing and "CL" is flashing on the display panel. I clean out the lint trap every time after a load is dried. I unplugged the dryer and let sit for 15 seconds in hopes to reboot it. I've vacummed out the interior trap. The ventilation duct is shot and a direct path into the wall. I checked the main circuit breaker and the GFCI and it is on...help!
  • 5,167 Answers
First, the 796 model means that the dryer was made by LG. The CL code usually means that the Control Lock (Child lock) is engaged. There are two buttons that you should press and hold for ~3 seconds to disengage the lock. There will be be a small icon (padlock or child's face and the padlock) with lines to the appropriate buttons. If only one button is used that icon will be on the single button. (Frequently it will be the Temp and Option buttons or just the Dry Level button. On some models, it's the Anti-bacterial or Rack Dry button.)
As for the lint trap issue, check the rest of your vent system. Sometimes, the cover on the outside of the vent comes loose and blocks the vent.
I hope this helps.
Posted on Jan 03, 2014
3 Suggested Answers
  • 183 Answers
SOURCE: I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. The lig
when you removed the screen from the inside you disconnected the wires from the 2 metal strips. now you need to remove the lower panel on the front. and reconnect them. you will need a T-20 torx and unplug the dryer to be safe. the wire will have 90 degree push on connectors and it does not have any polarity concerns. the two male connectors are real close to the top of the panel, maybe even slightly under the other panel. By the upper right of the silver fan duct.
Posted on Jan 03, 2012
  • 4961 Answers
SOURCE: kenmore dryer. drum spins but no heat. checked breakers, ok. heater element has no visable brakes or damage, how can i determine if the element needs to be replaced?
You might want to post this question in the appliances section.
Posted on Aug 21, 2012
Kenmore elite dryer won't steam
Every Dryer steams: throw a wet washcloth in with the clothing.
Don't waste money fixing useless features Carla!
Is the unit hooked up to a water source??
Model #? Help Me Find My Model Number RepairClinic com
Jul 04, 2016 | Kenmore Dryers
How do I remove the front oanel of the Kenmore Elite dryer model #796.8107, 796.9107?
Hello, You can look for aditional information in following web page http://www.searspartsdirect.com/repair-help.html?SID=MMLxSplashPage . Please try it, it could be helpful for You. Sincerely 1_27_2014_4_37_18_am.png
Jan 02, 2014 | Dryers
The Kenmore Elite Oasis Steam Dryer - almost new - worked well last week. This week no power to dryer; 220volts is present to dryer. Any ideas?
You might want to take a look at the vent pipe for lint. If the exhaust thernistor detects high temps it shuts down the dryer. Bravos service manual (same as oasis)
Apr 29, 2011 | Kenmore 67082 Electric Dryer
3 week old new Kenmore dryer The outside seems to get really hot when using even on 1st load is this normal
most likely your vent line is plugged up with lint and dust,make sure the outside vent is clear and if the vent line is long blow it out with a leaf blower and check the duct that the lint filter slides into,if that's not it call the factory if it's only 3 weeks old,let me know what you find
Jul 26, 2010 | Kenmore 63942 Dryer
I have the Kenmore Elite Gas Dryer (not steam). I
Take pantyhose around the inside and see if it catches.
Pay particular attention around the drum/door area.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 11, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
managemylife.com Logo
185 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
