Question about Generac Electrical Supplies
Generac 010060 mf6500
How do I change the oil and what weight oil should I use?
    Habit-Forming:
  • 78 Answers
THERE SHOULD BE A BOLT ON THE BOTTOM OF THE OIL SUMP THIS SHOULD BE ON THE SIDE TOWARD THE BOTTOM IT WILL LOOK LIKE THE COLOR OF BRASS TURN THE BOLT TO THE LEFT TO TAKE OUT LET THE MOTOR WARM UP BEFORE TAKING THE BOLT OUT THIS WILL THE OIL TO WARM UP. DRAIN THE OIL OUT AND REPLACE THE PLUG DONT OVER TIGHTIN THE PLUG . REPLACE THE OIL WITH 30 W OIL FOR SUMMER USE I HAVE A 10W 30 ALSO THIS WEIGH IS FOR SUMMER USE. USE A LIGHTER WEIGH OIL FOR WINTER USE.PLEASE TAKE OIL TO A RECYCLE PLACE . ALSO DONT OVER FILL THE MOTOR WITH OIL.
Posted on May 22, 2014
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
What weight oil does a 5550 watt take?
According to Generac for there Portable generators they recommend, Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter. Here is a link to get a manual if you need one. You will need your model number.
http://www.generac.com/service-support/product-support-lookup
Jan 30, 2016 | Generac Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
How do I change the oil on a generac pp5000t
Look in the owner's manual. If you don't have one, check Generac's web site and download one. There should be a drain plug at the bottom of the crankcase.
Oct 18, 2014 | Electrical Supplies
Reset change oil message on generac xp8000e
There is no way to reset it manually. It resets automatically after you run it a few hours.
Nov 03, 2012 | Generac 5606 XP Series XP8000E 12,000 Watt...
Generac 5623 GP6500 8000 Watt 389cc ohv will not stay running. Will only run for a few minutes then quit and then usually can't restart.
if the gerator runs pretty smooth up until then, i would suggest checking/changing your oil as the low oil level switch is picking up on a slight change in the oil level (easier to detect when oil is hot), if it start to give hesitation or reduction of power, check the choke, make sure its off.
Jun 19, 2010 | Generac 5623 GP Series GP6500 8,000 Watt...
I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
May 08, 2009 | Electrical Supplies
Electrical Supplies Logo
93 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
