Question about Wesc Bongo Headphones
No sound in left headphone
The cable to the left can of my headphones no longer works. It's definitely the cable as it started off by just cutting out every now and again and I would wiggle it and the sound would come back on, but now it doesn't work at all. There is still sound to the right one so I know its not the full cable, just the bit going into the left can. Is there any way this can be fixed?
    New Friend:
  • 12 Answers
Yes, sure. But it's a bit difficult, because you have to find the broken piece of it. Look for cuts in the wire. If you can see it, you can cut the protecting piece over the wire open or off and connect your wires again. Melt them together and it should work.
Posted on Jan 02, 2014
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: I recently bought Conga Wesc
Since the problem goes away when you don't use the extension cable, the cable is the trouble. One of the wires inside is broken. A new cable is what you need.
Posted on Jul 04, 2011
Why no more sound in left side? the right side is fine. i moved the left side like a seesaw, then i found where the sound occur. is it the wire connection problem inside the left side? what to do?
Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
Apr 21, 2016 | SOL Republic Master Tracks MFI...
The cable to the head phones has been cut can this be repaired?
yes it can be repaired
if the cable its cut in the middle just need to the to parts together with a knot
if calbe its cut from the joint with the headphone they need to be soldered
Apr 06, 2011 | Bose On-Ear Headphones
My skullcandy agent headphones are only working on the left side,,,,,its blank on the left side
Sounds like there may be a problem with the cord.
Try plugging in your headphones and playing some music and moving the cord around. If the sound cuts in and out then you have a lose connection and will need to replace your headphones.
Mar 25, 2011 | Skull Candy Lowrider Headphones
You hear one side if I move the cable to the sides and sometimes sounds the other hand I think can be a cable cut
It's a broken wire, obviously. it's probably broken near the jack or the headphone. ur going to have to replace the cable
Mar 08, 2011 | Skull Candy G.I. Consumer Headphones
I have Seinheiser HD 202 headphones that my dad bought me for Christmas about a year ago. About a few months ago the left earphone stopped working. I have tried messing with the jack but that didn't seem...
The fault is in the cable: you will have to dismantle the left speaker housing and start cutting from the cable until the break is removed then solder it back to the speaker - use an multimeter to check the continuity of the wires.
Oct 10, 2010 | Sennheiser HD 202 Consumer Headphones
My left headphone stopped working after a year or so. How can i fix this?
The copper wires inside the cable have broken. Since you don't know where the break occurred all you can do is to open the left headphone, remove the speaker, cut a piece of the cord and resolder it to the speaker. Test it, if it's fixed just put the headphone back together. If not, cut another piece. If you must cut more than a third of the cable to get it working then it's dead, just buy a new pair.
Jun 30, 2010 | Sony Bud Style Headphones
Hi one of my headphone stopped working there is no sound.
The most common problem at these cases is that the copper inside the cable is cut. This usually happens just after the headphone or just after the jack. You can try to locate it by moving slowly left - right, up- down the cable at either of these points. In case the cut is at the jack's side you might get it at a technician and ask him to replace it. If the cut is at the headphone's side or if the set is cheap there is no worth to fix it.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 13, 2010 | Philips SHS3701 Headphones
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Wesc Bongo Headphones Logo
163 people viewed this question
Top Wesc Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Wesc Audio Player and Recorder Expert? Answer questions, earn points and help others
