Question about Sewing Machines
How do I remove the case on my Viking 230 sewing machine
SOURCE: Viking sewing machine
http://www.sewusa.com/
Go here! FREE!
Posted on Feb 09, 2008
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
  • 8 Answers
SOURCE: Need manual for Scandinavia 200 sewing machine
I have one.
Posted on May 25, 2009
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
Thread bobbin on model 230
try this link for a manual, it should have the information in it, about how to thread a bobbin
Viking 210 230 250 Instruction Manual
May 02, 2015 | Husqvarna Sewing Machines
How do you remove the rose sewing machine case
That's a tricky fix. I recently fixed one (I'm a Service Tech). The spring is wedged into the front cover in the housing. The sewing head has to be removed to access the area. Suggest you take it to an Authorized Viking Dealer to have the work done. You can find the nearest Viking Dealer by going to Viking website - http://www.husqvarnaviking.com/us and clicking on Locate a Dealer
Feb 24, 2014 | Husqvarna Designer I
Thread broke inside the machine how do I remove the case from my Viking 230
If you do that, you'll void the warranty. Should be a cheap fix at any repair shop.
Jan 02, 2014 | Husqvarna Viking 1
How to clean a Viking 6430 sewing machine
You can find extensive information here: http://stitchesandseams.blogspot.com/2010/04/review-viking-6010-sewing-machine.html.
You really should get a manual. It will give you all the details about cleaning your machine. You start by opening anything you can (be careful with the screws and plates - I keep a magnet for holding these while I clean) Take a pipe cleaner and/or a small sewing machine brush and get out any lint. This is where you first need your manual. It will tell you how to clean the bobbing case. After all lint is removed, you will need to oil it in certain spots...again, you need the manual for this. Always use sewing machine oil in your machine. It is different than other oils. You can download your manual here: http://gotoes.org/sales/VikingSewingMachineManuals/ViewInfo.pl?Viking=1&Sewing_Machine_Model=6430. I think they charge $7 for it.
Jul 08, 2012 | Husqvarna Sewing Machines
I want to adjust my bobbin tension on my 230 viking sewing machine but I don't know how.
1. remove the clear bobbin cover
2. slide the needle plate towards you and remove it, do not pry it upward or you'll break the gray plastic housing that supports it.
3. remove the gray plastic piece that is on top of the black bobbin case.
4. remove the black bobbin case from the machine.
5.Look on the side of the bobbin case for a small hole with a screw deep inside of it. That is your tension screw. Turning it to the right increases the threads resistance and left loosens it.
You know you bobbin tension is in the right range with the following test: Have your machine in the ready to sew positon. Meaning the bobbin has thread on it and it's in the machine and the bobbin thread is coming up through the needle plate. Gently pull on the bobbin thread to feel the amount of resistance. It should be slight not tight. If you pull on the thread and feel a light resistance your problem is not your bobbin. If you have looping on the bottom of your fabric, the problem is the top thread.
Dec 27, 2009 | Husqvarna Sewing Machines
Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Mar 19, 2009 | Husqvarna Viking 1
Machine not working
I had this happen the first day I got my machine. The bobbin case has probably came loose from the holder. There is a step by step cleaning instruction in the manual and it tells you how to reset the bobbin case in the holder in the manual.
Nov 15, 2008 | Husqvarna Viking 1
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Oct 24, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
