Question about Samsung SCH-U470 Juke Cellular Phone
Phone cut off and only comes on when i plug it to computer
Yesterday i sat down finna plug phone to the computer.before i plugged it up it cuts off.so im like maybe the battery died then i plug it to charger the phone doesnt charge.but then i plug to computer its comes on but starts vibrating.and it never stops.then i try unplugin it the phone cuts off and i get it to come on again.
  • cassiuscampb May 21, 2009
    wat to do about the vibration it vibrates wen it is cut on
  • k srinivas ganesh
    k srinivas ganesh May 11, 2010
    pk mr cassius check ur phone pins at u plug and clean it and check whether any of them are broken and bund if its yes go to the shop where u buyed this tell him to ask him to solove the pin ok buy
  • 108 Answers
When Ur phone is on go to Ur settings and go to Ur sound or vibrate section and turn off the vibrate it over and when u what to turn on don't open that go to Ur nearest mobile shop ask him to solve OK buy OK and please rate me if u used my answer ok all the best
Posted on May 21, 2009
  • k srinivas ganesh
    k srinivas ganesh May 23, 2009
    go to the setting and solove ur problem
98 blazer will start and run for a while then cut off going down the road, but starts back up. Although yesterday it cut off then kept cut off every five mins. Once it sat though it ran for about five...
I think you are on the right track. It sounds like you have a fuel flow problem and those are the two items that immediately come to mind. I would start with the filter and then move on to the fuel pump if there is no change.
Jul 22, 2011 | 1998 Chevrolet Blazer
My vaio vgn-n250e sometimes will not cut on even when battery is charged and AC is plugged in. I actually havent used it in 2yrs thinking it was a battery problem, but yesterday (after 2yrs) i decided to...
I had a similar problem with another vaio turned out that the module that the power button is a part of (above the keyboard) had a bad wiring harness that connects it to the computers main board. After replacing the harness (looks like a tiny ribbon cable with 4 or 5 wires) the laptop was great again.
Aug 25, 2010 | Computers & Internet
Runs 5 mins. and quits seems to be out of gas. cuts out until it
Sounds like you have a stuck float in the carburetor. Sometimes a piece of grit will get in there. You can remove the float bowel location bottom of carburetor , turn off fuel first or pinch line shut needle nose vise grips do a good job for this. First lightly tap the float and blow though fuel line. If it sat a long time might just be a little varnish from old fuel. If still can not blow though line remove float and if need replace needle and seat.
May 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor just cut out. When I try to re-start turns over but cuts ou
crank sensor plugs and wires or coil packs not the module probably
Feb 28, 2010 | 1995 Buick Riviera
Subaru Legacy B4 - 1999 cutting out electrical/mechanical???
there is nothing worse to chase down than an intermittent electrical problem.the computer will only lead to the area if there is a code stored.
check all plugs are secure and all grounds.with it running,wiggleall the wiring harnesses and connectors and see if it dies.it may be heat related,so take a blow dryer and heat a few sensors to see if that causes a failure.
Aug 19, 2009 | 1998 Subaru Legacy
Fipped over
This is a search and find type of problem. Check all wiring, especially if the generator has a low oil cut off switch. Check the wiring to that. Also, check carburetor linkage and for any springs that may have come off. Check the linkage to the governor on the engine to make sure the linkage is not binding.
Aug 08, 2009 | Coleman Powermate Premium Plus 6250W...
My 2000 chevy blazer cuts off while you are driving.
This can cause your problem if the cat is plugged and cant exhaust it will shut the motor down
Mar 24, 2009 | 2000 Chevrolet Blazer
We have a panasonic cordless telephone # KX-TG5632. Yesterday, we were having some electrical work done and now that the power is back on, our corless phone does not work. There is power to the phone but...
Does the phone base receiver also have power? If so, then it sounds like a phone wire may have been cut. How extensive was this electrical work? If an electrician cut your phone wire by mistake they should take care of the problem at no charge.
To eliminate any problems with your cordless phone, try plugging in a standard phone where your cordless unit is to see if the line works.
Jun 10, 2008 | Lands Phones
Samsung SCH-U470 Juke Cellular Phone Logo
81 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
