Question about CAD Microphones ICM-417 Professional Microphone
My ICM 417 microphone doesnt show any sound but its detected
I bought a Microphone and a XLR to USB lead separately and it doesn't show any sign of sound on my computer .. but the device is connected.
The lead says 'plug'n'play' but the microphone came with no information.
i looked at all the settings on my computer, made sure the sound was up and what not. i checked everything really and all i could think of is that it was broken or needs a kind of software to be downloaded for it to work.
if anyone knows anything of such a problem would be awesome if you could contact me, its annoying watching it do nothing on my shelf:)
Doug Mitchell
4 Suggested Answers
  • 1137 Answers
SOURCE: I already have a 48volt phantom power and 2
Make absolutely sure that your cables are indeed balanced. Use a volt ohm meter to test each pin from one end of the cable to the opposing end of the cable. No two pins for example pin 1 on one end to pin two on the other end should show a reading. If they do it means you either have a short or an unbalanced cable.Phantom power will not work with unbalanced cables and you can damage the phantom power supply by using an unbalanced cable with it.
Posted on Nov 01, 2009
  • 140 Answers
SOURCE: I cant seem to be able to record anything on my
your CAD mic is a condensor mic and needs phantom power. If you don't have that it won't work. If you need phantom power you can get it from a small mixer. We here at proline carry some small multi channel mixers that have phantom power in them. call 215-736-8055
Posted on Jan 15, 2010
  • 9 Answers
SOURCE: what is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Posted on Aug 24, 2012
I have recently bought an AKG Perception 120 microphone and plan on recording through GarageBand on my Macbook Pro, but no sound is coming through. please help!
You say you have a XLR to USB adapter....so the version of the 120 you have is the regular XLR version, right? Well if it is, it needs what's called "phantom power" to work. It looks like they have a straight USB version of this mic, and that's what you should have gotten if you didn't want to use anything else. If you still want to use this mic as is, I would recommend a Focusrite Scarlett 2i2. I have one and it's great. I do have a pc though and I'm not sure about Mac. But it's a usb powered preamp that gives you two mic pre's along with headphone amp, and a volume control for your speakers and has phantom power built in. Great unit and around $120. NFI.
May 14, 2014 | AKG Perception 120 Microphone
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
I just bought the GXL2200 CAD microphone without the cabels,(thought they would've came with), what kind of cable do i need?
As with most microphones, these mics use XLR cables. You can get them online or in a music store in many different lengths. What you need is XLR male to XLR female, though most of the consumer-level stores will probably just call them "mic cables." Note that the thing you're plugging into will need to have an XLR input, and will need to provide phantom power in order for that mic to work.
Nov 09, 2013 | CAD Microphones GXL2200 Professional...
What is the best way to run the mic on desktop
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Mic to PC
This mic is a condenser type microphone. It needs phantom power (48v) to operate. Might want to buy a USB mic preamplifier box, like an M-Audio product, which will provide phantom power, xlr/1/4 inch inputs and USB output.
May 23, 2010 | Behringer C-3 Professional Microphone
What kind of outlet do i plug my cm-p35 microphone into?
The cm-p35 is a low-impedance (low-Z) dynamic microphone. It can plug into a mixer or microphone preamp that has XLR input connectors, typically found on professional audio equipment.
If you want to attach it to a computer, you'll need to buy an audio interface for it, either a pro-grade sound card with XLR inputs, or a USB-to-XLR adaptor, like this one at ZZounds.com
Jan 10, 2010 | Coby CM-P35 Consumer Microphone
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Oct 15, 2009 | M-Audio Luna Professional Microphone
I have problems connecting my microphone to my mac computer
what mic do you have? if one with xlr than you should buy usb external sound card with xlr option. can be m-audio. if you have usb mic than just connect with your mac via usb/go to system perferences/sounds/input and higlight your new mic.
hope that helps
Aug 03, 2009 | Logitech (980240-0403) Microphone
CAD Microphones ICM-417 Professional Microphone Logo
112 people viewed this question
Top CAD Microphones Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Tom Chichester
Are you a CAD Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
