Question about Dishwashers
Dishwasher motor running constantly
We are having difficulties with our integrated Baumatic slimline dishwasher model BDW45.1. Initially it displayed the E1 error code, which we understand is to do with the flow of water into the machine. We couldn't find any obvious problems so switched the machine off and on again. Now, when we turn the machine on using the control panel, a motor runs constantly and starts to smell of burning in seconds, so we switch it straight back off. It does this the second we switch on without us selecting a program or closing the door and it now doesn't display any error code. I assume it's the pump trying to drain water, so have taken the panels off at the front to see if there is any water in the overflow tray but it's completely dry. What I think is the float to detect overflow also seems to be at bottom of tray so doesn't seem to be raised. Any ideas? Thanks in advance!
  • Katie Neasham
    Katie Neasham Jan 02, 2014
    Yes I have tried that but no luck.
Did you try to pull the plug , maybe the pump or a relais kept being activated
Posted on Jan 02, 2014
5 Suggested Answers
  • 3422 Answers
SOURCE: stuck in two minute drain cycle
It is possible that the unit has leaked.
I want you to please check THIS link it will solve your problem.
Don't forget to do the banging test mentioned there.
Goodluck..
Posted on Feb 25, 2008
SOURCE: Asko 1555 Dishwasher will not
It might be the pump, or it might be an obstruction elsewhere. If you have an air gap on your sink/counter top, open it and check for debris. If it is clear, unscrew the main filter basket. There is a black plug on the left side of the bottom well and you can pull it out after removing the filter basket. Feel around for any obstruction, and see if it is clear. Pull out anything that is blocking it, and make sure that you can spin the impeller freely with your fingers.
I had an impeller break on me. It costs about $30 for the part, and is easy to replace if you are handy. Just remember to unscrew by turning clockwise. If the motor itself is bad, it's about a $75 part and about the same amount of work as changing the impeller.
Posted on Oct 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
  • 744 Answers
SOURCE: Water flooding onto floor when running.
The most common cause of this is a loose clamp on the pump discharge hose. It could also be a cracked hose, the hose came off (again, loose clamp). Check both ends - where the hose connects to the dishwasher AND where it connects to the sink drain.
Another possible cause is a bad pump seal, although this is less common, and usually open happens when the dishwasher is pretty old.
Posted on Jan 05, 2010
Testimonial: "Very quick and easy to follow instructions. Thanks."
Do you have a user manual for a Stoves slimline integrated dishwasher model number s450dw?
Contact Curry's or Stoves direct
http://www.currys.co.uk/gbuk/household-appliances/dishwashing/dishwashers/stoves-s450dw-slimline-integrated-dishwasher-19091081-pdt.html
Understanding how it works will help you get the most out of your Stoves product. Search by model number or scroll down to find an instruction manual.
If you dont find the manual your are looking for call our product helpline on
0844 815 3746
Manuals
May 26, 2016 | Stoves Dishwashers
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Jan 05, 2015 | Baumatic Dishwashers
Dishwasher wont stop working
You will have to check if the dishwasher pump is constantly running . If the only way you can stop is by turning off the power supply, the float switch has tripped. This means ther is either water collected at the base of the dishwasher due to a leak or the float switch is faulty. ther may be an error code on the panel if this is the case.
Jul 18, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
Have moved into new home with Bosch integrated slimline dishwasher. I just cannot seem to reach any actual manual on -line; so I could simply print it off. Pls help. Had PET done and they could not locate...
From what you are mentioning, it appears you are not able to identify the model number of your Bosch slimline dishwasher.
Usually the model number is located on the inside top corner of the dishwasher on a sticker along the left or right edge.
You need some reference before trying to locate a manual. Check this site.
Once you find the model number (atleast first 6-7 characters) you can download from the Bosch site.
Aug 05, 2011 | Dishwashers
Baumatic bdw45.1 integrated dishwasher
sorry i have no knowledge of this "baumatic" product line. please repost with another expert
Jan 28, 2009 | Baumatic 18 in. BHD45 Slim-Line Built-in...
Baumatic BDW5
http://www.manualnguide.com/dl/12334/ Here is the online manual
Oct 04, 2008 | Baumatic 23 in. BDW5 Built-in Dishwasher
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
Owen Barnes
