Question about Pioneer DEH-1320MP CD/MP3 Car Radio
No sound sudenly
Just went out in the car switched the stereo on and there's no sound from the speakers everything else seem to be working but just no sound it was fine the other day
Do you have sound coming out of your tv at all ?you may have you receiver set to through which bye passes your amp and sound run through to your tv . you may also have changed your input mode on the receiver as well . What cables are you using from you amp to the tv hdmi cables coaxial cables
Posted on Jan 03, 2014
Everything works on my stereo system,but there is no sound
Car Stereo Head Unit Install ** No Sound ** Amp Not ...
? 10:41
https://www.youtube.com/watch?v=wQ9bSdJGMjg
Mar 23, 2014 - Uploaded by PSYCHOTICNORMAN
Video for those who installed their head unit correctly, but got no sound / factory amplifiers not turning on. ... Car Stereo Head Unit Install ** No Sound ** Amp Not Turning On ** work around. ....Did everything to the letter on a 2001 Chrysler Town and Country and while I do have audio, my audio is cutting in ...
Everything works on my stereo system,but there is no sound ...
www.fixya.com/.../t26059653-everything_works_stereo_system_but_no
1 hour ago - everything works on my stereo system,but there is no sound lxi 4cd canger - Chrysler 2001 Concorde question.
Chrysler Concorde radio works but no sound Questions ...
www.fixya.com > ... > Cars & Trucks > Chrysler
Chrysler Concorde cars & trucks radio works but no sound questions and answers. ... Fixya - Solutions for Everything ... My 2002 concord lxi when ... CAR STEREO HAS POWER BUT WILL NOT OPPERRATE ... Question about 2001 Concorde ... ...sound from radio thru speakers Is there any popping when playing a CD or ...
Jan 19, 2016 | 2001 Chrysler Concorde
Stereo wiring diagram for 2005 Chevy trailblazer
Hi there:
Check this on 2005 Chevrolet Trailblazer Car Stereo Wiring Chart...
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 25, 2012 | Cars & Trucks
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
I have a 2008 model and there is no sound coming out of the speakers everything seems to work just no sound what can I do to fix
I can suggest looking in the owners manual under (fuses) either stereo or speakers.Do you have a after market system ? Could be over powering speakers
Jun 11, 2011 | 2008 Nissan Titan
I installed in my vehicle this head unit and everything seemed to work fine intially. Howevver, when I put the car back together and went back to setup the bluetooth feature for my phone, the entire...
Sounds like it could be a setup issue (software) inside the stereo itself. Maybe try and check out if the manual says any thing about the issue, if not im sure your local stereo installers could help you out.
Mar 01, 2011 | Car Audio & Video
There is no sound but everything seems to be working
Try moving the speaker -( ground) from the output of the stereo to the chassis ground - in other words, the speaker - from the wire harness needs to be connected to the chassis ground, making sure it is not connected to the harness - just the speaker. Just try 1 speaker to see if it works or not. If the unit lights up and all the functions seem to work properly but no matter what you cannot get sound out - including the test outlined here then you may possibly have an internal amp blown or another component on the circuit board of the stereo which could happen if the power / ground leads touched or were hooked up backwards. If it's new I'd take it back - if not ( or purchased used and no hope of getting your money back ) you may be able to take it to a stereo repair shop for repair.
Hope this helps and good luck!!!
Nov 27, 2010 | Alpine CDE-9841 CD Player
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
Chrysler town and country wiring diagram
2002 Chrysler Town and Country Car Stereo
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Orange/Tan
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
May 25, 2009 | 2002 Chrysler Town & Country
No output from speakers in car.
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
Oct 01, 2008 | JVC AM FM CD DET FACE CAR STEREO
Pioneer DEH-1320MP CD/MP3 Car Radio Logo
44 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
