Tv has vertical line in center
In the center of the TV there a line in the center of the that goes from the top of the TV to the bottom on the screen, tried to remove with remote control with menu
  • 3 Answers
Which TV? Which Model? is it a plasma?
Posted on Jan 02, 2014
3 Suggested Answers
SOURCE: How to unlock the MENU button on my TEAC RC-1058 remote control
Yes I know press timer and it will take u into the menu........
Posted on Jul 23, 2011
alicantecoli
  • 22326 Answers
SOURCE: tv wont turn on by pushing power bottom on
most likely their is but sorry i do not know them ,would have expected it to come on manually though to be honest
Posted on Dec 03, 2011
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Vertical red lines on screen
LCD correct?
There are 2 types of lines they may be showing, both requiring the replacement of the LCD Panel.
1. Delamination Lines- they are usually multiple vertical lines that do NOT flow from the top to bottom of the screen. Looks look water dripped down or something similar
2. Single/Multiple Vertical lines - This is normally 1 or maybe a few solid vertical lines that travel from Top to bottom. I belive in some cases they may only travel to the screen center.
In both cases, this will always show when the TV is ON. Even if there is no signal being input to the TV. There are other possibilities but these can be the most common. Both require a new panel.
Apr 29, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
My tv has this lines that bend over the front top of the screen and when an object moves through the lines the image appers from the the top of where the line begins...and the tv goes black every once and...
This sounds like a vertical deflection fault. There are some components that are failing in the vertical deflection area that are starting to fail. It is very common in many of the sets that there are electrolytic capacitors in the vertical amp section that are gong out of specifications.
When you have at the top or the bottom of the screen where the vertical axis is compressed, and the picture in the compressed area looks like it is inverted and going over on itself, this is called "vertical fold-over".
An experienced TV service technician should be able to service this for you.
Jerry G.
Apr 18, 2008 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
