Question about DIAL 911 IN CASE OF EMERGENCY SF116P
I PUT A NEW CLUTCH ON AUDI A4 PLUS A CLUTCH MASTER CYLINDER BUT SOMETIMES IT DOESNT ENGAGE GEARS
    New Friend:
  • 4 Answers
Does it do it on all gears? Did you change the flywheel or just resurfaced it. If it does it only on some gears then it could be a bad synchro. If it does it on ll gears and you chnged the master cylinder, try bleeding the system out or adjust your clutch pedal.
Posted on Jan 03, 2014
Clutch stuck in natural
Slide under the car to see if the clutch cylinder piston has come out of the cylinder. This will cause the clutch to be released without stepping on the pedal. If it all looks good then the clutch master cylinder is the problem.
Sep 24, 2016 | Audi 2002-2005 A4 Quattro B6, Quattro, 4Dr...
I just put a new slave cylinder and clutch master cylinder on a 2003 Honda accord 3.0 V6 six speed and you can shift the gears without the clutch pedal pushed in or the car started
that is normal if the gear synchro dogs ( teeth) are in line in the box
problems concerning a clutch are
slashing gears when trying to engage first or reverse with the pedal to the floor ---needs bleeding
slipping when the clutch pedal is released--- slipping clutch from the pressure not being released ---problem in master cylinder
reverse gear is the only gear not synchronised so even with the clutch depressed it is possible sometimes that it will not go into gear unless you let the clutch up to move the gears in the box then attempt to re-engage reverse
May 04, 2016 | Honda Cars & Trucks
My audi a4 is stuck in neutral I push the clutch in an cannot put into any gears? do u kno what it may be?
If the gears grind when you try to put the shifter into gear, chances are you've got a bad slave cylinder, or master clutch cylinder.
Feb 23, 2015 | Audi A4 Cars & Trucks
1998 Audi A4 will shift into gears, but not engage. RPM increase with no speed increase
It sounds like the clutch is completely gone, you will need to look and see if the clutch release bearing is moving, if it is then the transmission must come out and the clutch replaced.
Sep 13, 2012 | Cars & Trucks
Cant find the clutch reservoir on my audi a4 1.8 eastate r reg..
The Clutch Master Cylinder is located on the firewall inside the engine bay, and usually next to the brake master cylinder as the brake and clutch pedals are usually very close to one another. The Clutch Master Cylinder is responsible for transferring the clutch pedal pressure hydraulically to the slave cylinder to release the clutch. You can tell when your clutch master cylinder is dying or needs repair when you depress your clutch pedal and it slowly sinks to the floor and does not return. Since the entire system is a hydraulic one, the master cylinder also has a reservoir that holds the fluid used in the clutch hydraulic system. If you decide to change the clutch master cylinder it is a good idea to also get a clutch slave cylinder at the same time, as both units typically fail around the same time. When replacing your master or slave cylinder, its always a good idea to flush your entire system to prevent water buildup or air pockets from being present when you are driving. Also always keep an eye on the fluid in your reservoir, dirty fluid may mean that the internal seals are allowing dirt and contaminants into your master cylinder.
Oct 11, 2011 | 1997 Audi A4
2001 audi a4 1.9tdi, hi i need to replace my clutch master cylinder for the rod has snapped, but i cant seem to figure out how to remove the clutch and brake pedal so as i can fit the new rod onto the...
YOU NEED A HAYNES MANUAL BECAUSE IT WILL SHOW AND TELL YOU HOW TO REMOVE CLUTCH MASTER CYLINDER.TO REMOVE CLUTCH MASTER CYLINDER YOU HAVE TO GO INSIDE THE VECHICLE AND REMOVE THE LEFT SIDE UNDER THE DASH PANEL.YOU HAVE TO UNCLIP AND SLIDE OUT PIN SECURING THE CLUTCH MASTER CYLINDER TO THE CLUTCH PEDAL.AND YOU WILL HAVE TO UNSCREW THE MOUNTING BOLTS AND DETACH THE MASTER CYLINDER FROM THE FIRE WALL.YOU WILL NEED HAYNES MANUAL.YOU HAVE TO REMOVE OTHER THINGS BEFORE DOING THE JOB.YOU NEED FLARE OR INLINE WRENCH ALSO.
Jan 29, 2010 | 2001 Audi A4
No clutch resistance on audi a4
This sounds like a common Audi problem but its usually in early shape A3s and TTs. If you heard a snap, then possibly the pedal has broken where the clutch master cylinder connects to it. In this case you can just replace the pedal but it can be an early sign of a faulty master cylinder. If the pedal is ok, it maybe the master that has failed and needs replacing. Worse cases, the slave cylinder maybe faulty or even the release bearing could be sticking on the input shaft. Bleeding the brakes will not help, the clutch shares the same fluid and reservoir but is on a different hydraulic system. The clutch would need to be bled from the bleed nipple on the slave cylinder on top of the gearbox. This can be difficult without the car on the ramp, but is worth trying before replacing parts. What engine does it have?
Jan 23, 2009 | 2004 Audi A4
Gear Selection Audi A4
GEAR LINKAGE ADJUSTMENT IS UNDER GAITER PLUS REMOVE ASHTRAY .......BUT I WOULD CHECK FOR WORN OR DAMAGED GEAR LINKAGES ....CLUTCH FAULT WOULD BE THE NEXT THING
Aug 14, 2008 | 2003 Audi A4 Cabriolet
DIAL 911 IN CASE OF EMERGENCY SF116P Logo
75 people viewed this question
Top NATIONAL MARKER COMPANY Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a NATIONAL MARKER COMPANY Vehicle Part and Accessory Expert? Answer questions, earn points and help others
