Question about GE WBSE2090A Top Load Washer
Samsung My washing machine wont hold water. The water goes in, then drains straight out...why?
  • teenah Feb 18, 2008
    Hi Timbo
    Spot on!
    Took me a coupla hours to figure it out, but that was the prob...drain hose too low...doh'!!
    All seems so simple now!
    Thanx anyway!!
    Problem Solver:
  • 6 Answers
Hey this soundslike your washer might be syp[hening out your water which means that the drain hose is lower than the washer.another soluthion might be leakage,how high ias the hose or is there any water on the floor? good luck
Posted on Feb 11, 2008
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
WHY WONT IT HOLD WATER.FLOODS UNDERNEATH AND OUT DRAIN
Make sure drain hose is up high enough and not straight down to drain it has to be run up higher then the water level in tub to keep the water in the tub till the pump pumps it up and out.
Jul 11, 2014 | Hoover Washing Machines
Gmail.com I have just moved, my LG Turbo drum was working fine but i have set it up and now it wont hold the water, straight in straight out, can you help?????
The drain hose can not be sealed to the drain pipe, and it can not be shoved so far down the drain pipe that the end of the hose reaches the water level in the drain trap.
Mar 03, 2011 | LG Washing Machines
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
My washer wont hold water
Hi
Make sure your drain hose is not sitting on the floor.
You need to make sure the drain hose goes up to the hight of the tank and then back down to the drain.
If the hose is sitting low, then gravity will just drain the water out.
Let me know if this is not the case and I will dry and diagnose if there is a nother problem.
Ash
Nov 06, 2009 | GE WBSR3140DW Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
My washing machine will not hold water
Make sure your drain is at the proper height. Here is a photo for reference. The water draining straight thru can be caused by this. If this is not the problem, please let me know. Hope this helped and best wishes.
Sep 13, 2009 | Washing Machines
When starting to wash water goes straight out of
The drain you are putting the drain hose into needs to be at least 30 inches above the floor. You probably have the drain hose to low or laying on the floor for this to be happening.
Jun 09, 2009 | GE WBSR3140DW Top Load Washer
GE WBSE2090A Top Load Washer Logo
117 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
