Bush radios instructions - Audio Players & Recorders
Lost instruction manual for bush me-3710 DAB radio iPod docking station alarm can you send?
Hi there go here and download the manual www.bushaustralia.com.au/wp-file-browser-top/bushmanuals/.../BCR33DABIP.pdf
Jan 03, 2018 | Bush Audio Players & Recorders
Set the alarm on my bush ccr231dab alarm
My gran bought this and said it didn't come with any instructions. I eventually found that you can access the alarm setup menus by pushing the alarm button while the radio is on.
Jan 21, 2014 | Audio Players & Recorders
Bush manual instructions
Hi I have just bought a second hand Bush Alarm Clock Radio with iPod and iPhone Docking CCR232i Black.
Unfortunately it doesn't have the manual and I have spent ages trying to find one on the het to no avail,
would anyone know where i can find one please.
Any help would be much appreciated :}
Jan 12, 2014 | Televison & Video
I bought a bush dab radio ne-3125, was advertised as a clock/radio,is this right or is it just a radio ?
I had the same problem - alarm going off at midnight. Hold down the Menu and Select buttons at the same time to reset the radio. This removes the alarm. It will rescan and find all digital stations again but you will lose any presets.
Sep 07, 2012 | Audio Players & Recorders
How do i preset radio stations on my bush cmc22dab music system
Try to downlaod the user manual to your set from internet. If you feel any difficulty in downloading, send your email address to me by fieya. I'll send a copy of the manual to you by return mail. It will have all the details.
Apr 09, 2012 | Audio Players & Recorders
Bush radio ne3116 - i cannot preset channels
Choose the required station with up/down arrow buttons, press SELECT.Press and hold PRESET button until number flashes.Quickly scroll through preset channels with arrow buttons.When required preset chosen, press SELECT.
Voila: station saved!
Took me about 15 minutes to figure it out, as bought radio second-hand with no instructions, and none on internet, until now!
Sep 14, 2011 | Audio Players & Recorders
Driver side door problems
Get a set of hinge pins and bushings. There is a tool that you can get at harbor freight or tool king for removing the bushings. I use a floor jack and a 4x4 block of wood to support the door. you will need a spring compressor to remove the door "hold" spring. Once you have that removed, you can use a brass drift or similar rod to tap the pins out. once they are out the door will be resting on the wood. I use heater hose to wedge between the fender and the door to prevent dents and scratches. tap out the bushings. ever so gently tap in the replacements. apply a generous helping of white grease to the bushing and pin. line up the door and insert the pins. you may have to apply an ever so light amount of tapping pressure on the pins to set them final. reinstall the door spring and lube the joints with white grease. be proud of yourself as your just saved a **** load of money.
May 21, 2009 | 2000 Chevrolet Blazer
201 people viewed this question
 Grubhead
Grubhead
