Question about Ragalta RWC-551 Hot and cold ss water cooler
White plastic screw that attaches spout to cooler broke in halff
Have spout need part that holds spout in place
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
Maytag bravos washer making a grinding noise. It seems to make this noise when the drum is moving, any suggestions?
Unplug machine and tilt it back. Pull down the white insulation board. remove the two screws holding the white/clear plastic guard in place 5/16 nut driver. and check the gear and belt ours had come off. Now it works just like new you will need a 13mm hex for putting the gear back up.
Apr 28, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Unable to read disc
If your console is unable to read disc, then there seem to be a problem with the console, and the problem most likely is as a result of a bad laser/lens inside the console.
To replace the lens of the nitendo wii console, remove the two flip up panela on the side of the wii to reveal the black face plate with the controller ports and memory card slot.
Then remove the three screws located underneath the flip up panels using the fine phillips head screwdriver, then remove the black face plate.
Then remove the two tri wing screws located underneath the face plate. There are also two phillip head screws under the face plate but you can leave them in place.
Use a scalpel to peel off the two white stickers that are covering the screws located near the two front rubber feet on the bottom of the wii. This will reveal two black tri wing screws.
Use the scalpel to remove the two back ribber feet on the bottom of the wii, this will reveal two silver tri wing screws. Remove the two black tri wing screws and the two silver tri wing screws revealed on the bottom of the wii.
Use the scalpel to remove the rubber foot that is covering a screw in the top left corner at the back of the wii. Remove the screw using the fine phillip head screwdriver. Then use the scalpel to remove the white sticker covering the screw directly below the bar code on the back of the wii. Remove the screw with the tri wings screwdriver. Then use the fine phillip head screwdriver to remove the screw that is holding the battery cover in place on the back of the wii. This will reveal another screw that you can remove with the tri wing screwdriver.
Remove the front face plate of the wii, be careful because it is still attached to the console by a black and red wire. Disconnect the wires by lightly pulling on it. Remove the wii shell casing by gently lifting the separating it from the internal electronics of the console.
Remove the DVD drive by taking out the four corner screws using the large phillip head screwdriver then lift up the DVD drive and disconnect both power cable and ribbon cabble connecting it to the console.
Turn the disassembled console upside down, remove the two screws holding the DVD citcuit board in place, disconnect the three ribbon cable that are attached to the DVD circuit board, Use the tweezers to free the wires that are still connected to the circuit board from the plastic clips, Lift up the DVD circuit board and remove it from the way, then remove the lens case that is holding the lens ribbon cable in place.
Use the tweezers to remove the lens casing by lifting up on one side hooks that are holding it in place. This will reveal the laser lens unit, Which is held in place by two metal bars. Take out one of the metal bars by first removing the screws located next to it, and then gently lifting up on the plastic tab so you can slide it out.
Remove the laser lens unit and turn it over to reveal a white plastic part held in by a screw. Take out the screw so you can remove the white plastic part. You will need the part to install the replacement lens.
Attach the white plastic part from your old lens to your new lens using the same screw from the old unit. Place the new lens in the console and reassemble The DVD circuit board.
Remove the two solder points located on the lens ribbon by using a hot soldering iron.
Then reverse the process to reassemble the console.
Take care and good luck.
Hope this was helpful
Dec 03, 2010 | Nintendo Wii Console
MY WHER25 REV. OS. IS LEAKING AT THE HOLE IN THE BOTTOM OF THE SPOUT . i CHANGED THE FILTERS.. IT STILL LEAKED.. I CHECKED THE DRAIN GOING INTO THE P-TRAP .. IT WAS CLEAR .. PLEASE HELP
Remove the faucet spout and unscrew the screw keeping the white plastic piece on the bottom (of the faucet). It's where the red and black tubes enter. Pull out the white plastic with the tubes and clear it of debris (usually placed there when your disposal backs up the black tube, which serves as the filter's drain tube). Once it is cleared of debris, make sure the black rubber washer is back in place (it may be stuck in the faucet, so look for it) and replace the plastic, screw the screw back in, and secure the faucet again. I had this same problem and doing this solved it. Should take about 5 minutes or so. Good luck.
Dec 02, 2009 | Whirlpool Home
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Danby wine cooler model dwc172bl thermostat replacement
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Jan 18, 2009 | Danby Silhouette DWC512BL Wine Cooler
Door handle broke off
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can get Samsung parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Ragalta RWC-551 Hot and cold ss water cooler Logo
24 people viewed this question
Top Ragalta Water Filters & Coolers Experts
Tom Chichester
Are you a Ragalta Water Filter and Cooler Expert? Answer questions, earn points and help others
