My Maytag Centennial washer model MVWC6ESWW1 will not fill or agitate. it will spin and pump out the water
  • 96 Answers
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Posted on Mar 13, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
TheMobilian
  • 8220 Answers
SOURCE: centennial washer, will fill with water, wont spin
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Posted on Apr 30, 2011
Jahn27
  • 1554 Answers
SOURCE: Maytag Centennial Washer model MVWC6ESWW1
It sounds like this is a clutch and brake assembly problem. The clutch spring must provide the necessary pressure for the lining to turn with the hub and the clutch tab to push the brake cam driver and release the brake. The clutch spring of your washer must be weak or the clutch lining is worn causing it to slide and not release the brake. This prevents the tab that holds the clutch spring to force the brake cam driver, release the brake, and allow the basket to spin particularly when the machine is under load. This is manifested in the spinning of the drum when the machine is empty. The clutch and brake assemblies are located just below the tub and the excessive heat resulted from the friction between the clutch lining and the clutch hub.
Remove the thrust washer from the agitator shaft then remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip using a screwdriver. Unsnap the clip and the clutch retaining ring the slide the clutch off the agitator shaft. Make sure to retain the washer located under the clutch.
Install the new clutch assembly on top of the gearcase then insert the clutch band and hold it in place. Using a pair of needle-nose pliers, place the end caps on the clutch spring and compress to insert into the open end of the band. Release the tension on the spring and the band will stay in place the reinsert the retaining clip on top of the clutch.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 30, 2011
Maytag Centennial is filling with hot water on cold setting
Probably the fill lines were reversed. The installation guidance tends to be poor.
Jun 15, 2017 | Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Owner's Manual For CENTENNIAL Commercial Technology Washer - Model No. MVWC6ESWW1
Maytag has many of the manuals for their washers available at their site. Go to https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10562&langId=-1&storeId=10212&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView and enter the model number of the washer.
The direct link to the manual for the Maytag Centennial MVWC6ESWW1 is https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10330943.pdf . Additional manuals are available here https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212 . (This includes the manuals in Spanish, installation guide and parts list.)
I hope this helps.
Aug 06, 2011 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
