Question about ATI Computers & Internet
Agp card how to use on xpc
Installation
After i changed my power supply (due to short circuit), i cant hear any sounds in my audio. i checked to device manager but no problem in my audio controller, no problem in speaker also. i formatted my PC...
Hello Roydgreat, short circuits unfortunately can cause more damage than just the power supply. There may be a chance that it has damaged your sound card or a portion of it. If you can borrow a friends sound card you could double check to see if that is the issue. They aren't very expensive if you were considering getting a new sound card to install into your computer. It's not a guarantee that the sound card was damaged in the process but it is a possibility and if you can grab a friends audio card and install the drivers for it and then see if it works, it'd probably be the easiest way to test this theory. Hopefully this helps, have a great day Roy!
May 15, 2011 | Shuttle XPC SK41G (XPC-SK41G-SHUT) PC...
Hi. I want to play games on my Acer Aspire SA80 Desktop, but every time I install the game, it says the video card is not supported. I don't know what to do. Please help!
As per Acer this computer model has a Integrated SiS Mirage Graphic onboard card or a seperate
AGP 8x Add-on Card (selected models). It looks like the game you are trying to install requires advanced graphics card.
Please specify the game you are trying to install and also specify if you have a AGP card installed (and what is the make and model of the same).
If you do not have a AGP card installed , we can check the game specification and try to install a AGP card and check with it.
Jan 04, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Will a NVIDIA GeForce FX 5500 video card work on a P4B533-E motherboard?
HI Lau_kua08,
First off, your motherboard is a AGP 4x slot, and the Card is a AGP 8X card. However, NVIDIA based graphic cards which support AGP 8x mode (Accelerated Graphics Port) follow the AGP 3.0 specification. The AGP 3.0 specification retains backwards compatibility with older AGP 4x technology. All NVIDIA Geforce and Quadro GPU's which support AGP 8x mode are downwards compatible with AGP 4x motherboards. When a graphics card which operates at AGP 8x mode is installed on a motherboard which only supports up to AGP 4x mode, the card will automatically switch to AGP 4x operation.
So, yes it will work.
Good Luck,
Mark
Oct 27, 2009 | ASUS P4B533 Motherboard
How to instal agp slot in intel Board d845GVFN
AGP graphics adapter is installed only to an AGP slots not on the PCI.pci-mb.jpg slots as shown. You should change your AGP to PCI type graphics adapter.
Hope it works,
geloaa
Oct 08, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Powercolor Radeon 9550 R96 256mb Card - Lights on, noone at home!
Depends on the video card ,it might require more power ,200w is fine for onboard but add other components and the system needs more power.
Disconnect the harddrive or CD ROM drive and see if the system will start.
If it starts then you will need more power 300-400w at least but shuttle power supplies can be expensive to get.
May 18, 2009 | Power Color RADEON 9550 R96-LC3 (128 MB)...
No video when card is installed
I DONT HAVE MOTHERBOARD DRIVES SO CAN'T HEAR A SONGS & CAN'T SEE THE MOVIES OR VIDEO'S IT'S A MY BAD PROBLEM
Apr 09, 2009 | ASUS P4P800-VM Motherboard
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
Need nvidia mx400 64m 64bit ddr 4x agp driver
i lost my the driver cd for my nvidia mx400 64mb 64bit ddr 4x agp card. i dont have an internet connection on the pc in which the agp is installed. can u send me or help me to find the specific driver for the model of my agp card.
Nov 16, 2008 | Nvidia GeForce2 MX200 64MB 4x AGP Graphic...
Driver is not working
strange... even WinXP has got the drivers for that ATI AGP card.
Apr 07, 2008 | ATI ALL-IN-WONDER 9600, (128 MB) AGP...
Fx 5200 geforce graphic card
You did not mention if the board your running has an integrated video card on it. If it does & you have added the FX 5200 AGP you need to make a change in your bios. Set the bios to see AGP. Re-check the insertion of the AGP card. Remove the video card. Use a strong flash light & look into the AGP slot. Use canned air & blow out the AGP slot. Re-seat the video card evenly into the AGP slot. Try again.
Feb 13, 2008 | XFX GeForce FX 5200, Graphic Card
Computers & Internet Logo
23 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
