Panasonic rp wf910h - Audio Players & Recorders
Hello. I have a problem with my headphones Panasonic Rp Djs200. When i connect them to my laptop is not working. I have windows 10 and all the updates. What should i do?
Could be a hardware problem if the driver rollback/ reinstall and troubleshooting facility hasn't worked.
Presumably the headphones work on other appliances and known good speakers or headphones consistently don't work from the headphone socket?
It probably needs to visit the laptop doctor...
Jun 30, 2016 | Panasonic Rp Djs200-W - Headphones
Where can I buy a panasonic ergo fit rp-HJE120-D
http://www.amazon.com/Panasonic-RPHJE120D-In-Ear-Headphone-Orange/dp/B003ELYQGG
Apr 13, 2013 | Panasonic RP-HJE120-A In-Ear Earbud...
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hey I have lost the Ear pad to my panasonic rp-htx7 and need to know where i can replace it! It's only a clip on thing so im hoping it shouldn't be hard
See my tip on replacing dodgy cables plugs on headphones. Just click my name. Link to a site that sells them at the bottom.
Nov 23, 2010 | Panasonic RP-HTX7 Consumer Headphones
RP-WF940T instructions
Try the Panasonic website they have free user manuals to download.
Mar 06, 2010 | Panasonic RP-WF930 Consumer Headphones
 Grubhead
Grubhead
