Question about KitchenAid KUDK01TK - Multiple Color Built-in Dishwasher
Dishwasher not running
When i select the cycle and option buttons they light up but when I press start nothing happens
  • wcervi May 21, 2009
    Thanks for the quick and detailed response to my problem. I will try all of the aforementioned solutions. I really appreciate your help!
    Ill be darned if just turning off the power didnt just fix my dishwasher! Fixya and ginko are the best! I will be telling everyone I know about this site and I am a realtor with Coldwell Banker and deal with many homeowners!
  • KitchenAid Master
  • 19,396 Answers
Check door lock, if sensor in there is stuck the machine won't operate
Check also the water level sensor, if it is stuck the cycle wont start.
If the machine is still stuck then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, impeller, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
Posted on May 21, 2009
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Maytag mdb7749awb1 won't start
Thank you very much after doing the normal heated dry three times all the lights on the panel lit up and my dishwasher started running
Aug 18, 2012 | Dishwashers
Not starting
Getting Started
1. Load dishwasher (See Preparing and Loading Dishes).
2. Add detergent (See Dishwasher Dispenser & Detergents).
3. Add rinse aid, if needed (See Rinse Aid).
4. Close door to latch.
5. Select desired CYCLE (See Cycle Chart).
6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
8. To start, press START/CANCEL pad.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Kitchen Aid dishwasher won't start
If the power indicator is on check the latch as alot of the kitchen aid dishwashers wont start if the latch is out of alignment.
Jul 02, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
282 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
