Question about Magic Bullet Nutribullet Blender
Nutribullet makes a loud noise when turned on
My nutribullet makes a loud noise when I run it, why is this likely?
Motor won't run
Go to the manufacturer website and maybe you can have or get warranty repair. It could also still be under warranty.
Jul 11, 2015 | Magic Bullet Nutribullet Blender
Cup wont press down onto motor grips
Have you got something caught in it? Is it still under warranty? I am guessing but the mechanism inside the base should drop when you push to twist. Check is this is happening. If not then that may be the problem
Apr 21, 2015 | Magic Bullet Nutribullet Blender
How do i repair my nutibullet .I have power but the blades on both extractors are not working . It gives out a loud vibrating buzzing sound when pulsing .last blast i did was watermelon and it worked...
Do not try repair it manually,as its a concern of electronic gadget,& its hazardous.Get it done from a service agent or instead prefer ton buy a new one.I would suggest Magic bullet blender nbr1201.The Magic Bullet consumes less power than Magic Nutri Bullet when you compare Nutribullet Vs Magic Bullet, but it is more when it comes to the price factor. Though it is not that powerful, you can get Magic Bullet at much cheaper price than Magic Nutri Bullet.Go to the link to know.
Nutribullet And Magic Bullet Difference
Feb 23, 2015 | Magic Bullet Nutribullet Blender
Fax number for company called Nutribullet?
If they gave you a number, that is not a fax number, try to call it. Or try to locate their customer service department. Sending a fax about a problem with an order won't ensure that the proper people get the information to rectify the problem.
Also Try calling this number, and filling out the form on the NutriBullet website.
"Our customer service is available Monday through Sunday from 9am to 8pm, Eastern Time by phone at 1-855-346-8874."
https://www.nutribullet.com/customer-service.html
Feb 05, 2015 | Magic Bullet Nutribullet Blender
I bought a nutribullet less than a yr and it just stop working it does not smokeor smells like it burned.
ck where the cup goes onto the top make sure it turns on to lock on that is were the switch is to turn it on
Jan 20, 2015 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
How do I remove the nutribullet jar that is stuck to the blade housing?
strip the housing to release the blade, it is the only way to go.
Jun 30, 2014 | Magic Bullet Nutribullet Blender
How to open nutribullet jar stuck on blade base?
try heating the jar with hot water before removing it
Nutribullet manual
www.nutriliving.com/forums/were-listening/nutribullet-support
Jun 15, 2014 | Blenders
Magic Bullet Nutribullet Blender Logo
115 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
