Question about Dewalt Saws
Motor works but blade keeps stopping - Dewalt Saws
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Bad gears or the blade isn't tight
Posted on Jan 27, 2014
My Ryobi 10" chop saw was stopping mid-cut. Why is it making an awful noise now?
The nut that holds the blade on May gave come loose. Or motor is shot
May 02, 2015 | Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
Motor hums but blade will not rotate
Sounds like a start capacitor.
Feb 19, 2012 | Saws
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
Motor noise from Bosch freezer 'noFrost' unit area sounds like a fan blade striking something on each rotation. Stops when door opened; starts and continues for several minutes when door closed.
Hi, If you say it stops when the door is opened and starts again when you close it, it is the evaporator motor in the freezer its self. The blade/prop is hitting maybe a chunk of ice or may be a part of the casing some where. This motor is 120 volts and the blade is either aluminum or plastic. You can fix this on your own if you are a handy guy, you just need to get back to where the motor is and plug it in to see what it is hitting.The bearings may be going out causing the motor shaft not to be true and hitting. You will be able to see the motor turn and know if it is straight. I don't believe that's the problem, something has moved slightly causing the blade to hit it on start up.I have seen this happen many times.Once you get the cover off, it should be a quick fix for you. Keep me posted. If it turns out to be the bearings as you will see the shaft wabbling, take it out, make sure you unplug it, an get the name Bosch, model, and serial numbers and get one at a appliance parts house. Like I said, I don't think its the bearings or it would stop working or be real noise all the time. The blade is just hitting something small. Keep me posted,
Sincerely,
Shastalaker7
Mar 23, 2010 | Freezers
Blades stopped on my 02 cool fan.
I love the 02 Cool rechargeable/battery operated fans and have them running in my home and office daily. However, they do have a limited lifespan. I get about 6-9 months of daily use before the fan motor goes dead and the blades stop turning. However, I'll keep buying them. I live in an area where we frequently lose power and the rechargeable/battery operated feature pays off when it does so on a hot day.
Jun 25, 2009 | Panasonic Dryers
Saws Logo
87 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
