Where can i get an on/off switch for a heat essentiial oil filled radiator
No indicator light on buttons on switch jumped it with a wire and heat came on
  • 156 Answers
Newark Electronics or any other electronics distributor. You will need the precise size of the switch and the electrical rating of the switch and the contact configuration to determine a suitable replacement.
Posted on Jan 24, 2014
5 Suggested Answers
  • 34 Answers
SOURCE: Lakewood oil radiator heater quit
visit http://www.lakewoodeng.com/html/parts.html for service center info and parts.
Posted on Apr 18, 2009
SOURCE: The Lakewood 5500 oil-filled heater has stopped
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Posted on Jan 11, 2010
freetek
  • 5568 Answers
SOURCE: my oil filled radiator trips the mains after a few
Try changing circuits (plug into one not protected by the same breaker.)
While the heater element can fail in your heater, I have had to replace several breakers after only a few years use after they became overly sensitive.
Posted on May 24, 2010
  • 123 Answers
SOURCE: I have a heater HO-0218 oil filled radiator and it
This is a problem with the heater element. You will need to buy a new one.
Posted on Jan 27, 2011
Unit does not heat.
-Possibly dirty contact or burn elements.
Good luck
Mai
Nov 12, 2013 | Honeywell HZ-690 Oil Filled Radiator...
Oil filled radiator (lervia oh-gf-9-20) not heating up.
hi, i had the same problem the red lights would come on and also the fan would work but the actual radiator would not heat up.
as mentioned in an earlier answer that it was the inline fuse which is actually a thermal fuse and quite slim and you would miss it if you did not look hard enough, my one was on the blue cable under 2 inches of heatsrink tubing.
you would have to take small scissors and carfully snip away and expose the fuse and i would recomend taking a picture of the wire so you can check the picture again when replacing the fuse.
i brought a 110c fuse from maplin for 82 pence and also brought what they call butt crimping connectors as you can not soldier the fuse on the wire.
basically crimp the fuse on the wire and dont forget to use heatshrink tubing to cover the wire and fuse and it should work.
Apr 04, 2012 | Lakewood Heating & Cooling
The Orange "ON" indicator light
We need lots more info...oil won't heat ?...is this a vacuum cleaner ? Pop corn popper ? Oil filled radiator heater ? Company name...model number...anything ?? Help us help you. Thanks.
Nov 06, 2010 | Vacuums
My lakewood oil filled heater model 5600/7 just stopped working. It won't turn on..no lights. There is no history of tipping over.
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Apr 06, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Heater does not heat when turned on. indicator light stays red
check oil overtemp senser or heating element, some of the newer ones have a circuit board with default codes, check for codes,unplug, plug back in and see if it works
Jan 30, 2010 | Honeywell HZ-710 Oil Filled Radiator...
The Lakewood 5500 oil-filled heater has stopped working. When switched on, it's indicator lights come on but the heater doesn't heat. I looked for a fuse but found none visible. What must I do?
Jan 08, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
